chan000
Broadband keeps dropping out and very slow
Hi team,
Since last 2 days, I keep getting issues with my broadband, it is very slow and keeps dropping out less than 10mins.
I tried doing the online tests and did the basic cable checks and also rebooted it often.
When I run the test now is says as below:
Any help how to solve it?
There's a network issue which maybe affecting your broadband service
What does this mean?
This issue is caused by interference on the cabling coming into your home.
This will cause intermittent speeds and performance may vary.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Broadband keeps dropping out and very slow
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
