on 08-11-2023 21:37
Hi, for the past 2 weeks I’ve had intermittent broadband speed. I should be getting 250mb plus and I’ve got 17mbs today, this isn’t intermittent when I’ve had the issues for 2 weeks now. I’d like a refund and the issue resolved or the service removed. I’m at SW14 7PB, how can I get this resolved please?
on 08-11-2023 21:43
See this...
First thing is to check for any “known network faults in your location - Look in 2 places
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
Report back
on 08-11-2023 22:09
Always check the status! They say they have repaired it and bang, it lasts for 24hrs and down again! I’m getting just over 15mb now! Basically they are rubbish. Switched from BT and regretting this
on 08-11-2023 23:00
So this is by wire to the hub?
on 09-11-2023 14:25
You need to say how you are measuring the speed. Wired or wireless? What devices?
on 11-11-2023 15:01
Hi Dear105,
We're sorry to hear you're having an issue with your internet speed. Taking a look at things this end, I can see the hub isn't in a great shape. The signal levels are too low and the power being provided on both the upstream and downstream also needs adjusting. We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you.
I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
