The-chief
  • 8
Message 1 of 14
Broadband issues
  • Hi all,
I was hoping someone could help solve my problems
jpeg1
  • 7.58K
  • 391
  • 1.48K
Message 2 of 14
Re: Broadband issues
If you want help, you'll need to post full details of your contract, your equipment, how it's connected and what the problem is.
The-chief
  • 8
Message 3 of 14
Sorry volt 350 , hub 3
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062-b.cm
SFID14242
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
23/04/2022 20:11:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2022 19:23:34noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2022 10:58:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2022 14:07:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/04/2022 21:12:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/04/2022 08:22:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/04/2022 16:53:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/04/2022 20:14:5noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2022 02:05:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2022 16:25:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2022 16:24:40Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/03/2022 16:23:36noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2022 23:45:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2022 23:44:29criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2022 23:38:12Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2022 23:38:7criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2022 23:38:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/03/2022 23:38:6criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/03/2022 23:23:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Cable Modem StatusItem Status     Comments
203000000
Locked
Ranged Upstream Channel (Hz)
25800000
Locked
Provisioning State
Online
Power (dBmV)SNR (dB)ModulationChannel ID1203000000840256 qam921390000008.940256 qam131470000008.640256 qam241550000008.440256 qam351630000008.540256 qam461710000008.940256 qam571790000008.540256 qam681870000008.540256 qam791950000008.340256 qam8102110000007.840256 qam10112190000007.940256 qam11122270000007.540256 qam12132350000007.540256 qam13142430000007.540256 qam14152510000007.440256 qam15162590000007.340256 qam16172670000007.340256 qam17182750000007.140256 qam18192830000007.140256 qam1920291000000740256 qam2021299000000740256 qam21223070000006.840256 qam2223315000000740256 qam2324323000000740256 qam24
12580000047512064 qam12
23940025847.3512064 qam9
34620027347.3512064 qam8
43260000047.5512064 qam10
3ATDMA0000
  • 35.13K
  • 3.42K
  • 6.69K
Message 4 of 14
What problems are you experiencing?
Post up the Dowstream table of RS errors
jpeg1
  • 7.58K
  • 391
  • 1.48K
Message 5 of 14
And as requested, details of the devices you are using and how they are connected to the Hub - ethernet or WiFi.
The-chief
  • 8
Message 6 of 14
Hey buddy
cube,Ethernet,cat 7 , and Ethernet or wireless can connect everything to hub either or
The-chief
  • 8
Message 7 of 14
31470000008.840256 qam2
41550000008.540256 qam3
91950000008.440256 qam8
1Locked40.9210
2Locked40.9150
3Locked40.9240
4Locked40.9220
5Locked40.9270
6Locked40.3290
7Locked40.9160
8Locked40.9250
9Locked40.990
10Locked40.9100
11Locked40.970
12Locked40.9190
13Locked40.9160
14Locked40.9280
15Locked40.9140
16Locked40.3320
17Locked40.3210
18Locked40.3230
19Locked40.3270
20Locked40.3300
21Locked40.3290
22Locked40.3270
23Locked40.3490
24Locked40.9440
jpeg1
  • 7.58K
  • 391
  • 1.48K
Message 8 of 14
So what exactly is your problem?
  • 20.5K
  • 828
  • 2.2K
Message 9 of 14
They using router mode
jpeg1
  • 7.58K
  • 391
  • 1.48K
Message 10 of 14
@The_Chief
According to the data you've posted there is nothing wrong with your broadband connection. So I'll ask once more, what is the problem you are posting about?  Give full details please, otherwise no one can help you.
