on 20-09-2022 00:26
Where to begin? I had my hub 4 swapped out last week as it was playing up, it was replaced by a hub 5, now I'm not sure if this is relevant or not however all was fine speeds were as I expected until Saturday night / Sunday morning 17 into 18th. Around midnight my connection dropped and the hub went into a reboot cycle lasting about an hour, since then my speed has been all over the place with uploads slowing to an absolute crawl and latency ranging from 50ms up to a point where samknows fails. This is the current sam knows result along with the logs from the Hub 5. It's worth noting for about 10 mins after a reboot the upload speed hits just over 50Mbps and then drops to around what you see below. Thankfully as today has been a non-working day I haven't had to worry about latency or upload speeds but I have a day full of meetings tomorrow so it will be fun to try and work if those metrics are indeed correct. I'm hoping one of you kind folks can cast your eye over this and see something obvious. Also interested to know if anyone else is experiencing similar issues.
And the logs:
Router status
Acquired Downstream Channel(Hz) | 331000000 | Locked |
Ranged Upstream Channel(Hz) | 46200000 | Ranged |
Provisioning State | Online | Operational |
1 | 331000000 | 4 | 42 | QAM 256 | 25 |
2 | 139000000 | 5 | 42 | QAM 256 | 1 |
3 | 147000000 | 4.8 | 42 | QAM 256 | 2 |
4 | 155000000 | 4.7 | 42 | QAM 256 | 3 |
5 | 163000000 | 4.5 | 42 | QAM 256 | 4 |
6 | 171000000 | 4.4 | 42 | QAM 256 | 5 |
7 | 179000000 | 4.3 | 42 | QAM 256 | 6 |
8 | 187000000 | 4.4 | 42 | QAM 256 | 7 |
9 | 195000000 | 4.7 | 42 | QAM 256 | 8 |
10 | 203000000 | 4.7 | 42 | QAM 256 | 9 |
11 | 211000000 | 4.9 | 42 | QAM 256 | 10 |
12 | 219000000 | 4.8 | 42 | QAM 256 | 11 |
13 | 227000000 | 4.7 | 42 | QAM 256 | 12 |
14 | 235000000 | 4.7 | 42 | QAM 256 | 13 |
15 | 243000000 | 4.6 | 42 | QAM 256 | 14 |
16 | 251000000 | 4.5 | 42 | QAM 256 | 15 |
17 | 259000000 | 4.5 | 42 | QAM 256 | 16 |
18 | 267000000 | 4.6 | 42 | QAM 256 | 17 |
19 | 275000000 | 4.5 | 42 | QAM 256 | 18 |
20 | 283000000 | 4.5 | 42 | QAM 256 | 19 |
21 | 291000000 | 4.5 | 42 | QAM 256 | 20 |
22 | 299000000 | 4.4 | 42 | QAM 256 | 21 |
23 | 307000000 | 4.3 | 42 | QAM 256 | 22 |
24 | 315000000 | 4.3 | 42 | QAM 256 | 23 |
25 | 323000000 | 4.3 | 42 | QAM 256 | 24 |
26 | 339000000 | 4 | 41 | QAM 256 | 26 |
27 | 347000000 | 3.9 | 42 | QAM 256 | 27 |
28 | 355000000 | 3.9 | 42 | QAM 256 | 28 |
29 | 363000000 | 3.9 | 42 | QAM 256 | 29 |
30 | 371000000 | 3.8 | 42 | QAM 256 | 30 |
31 | 379000000 | 3.6 | 42 | QAM 256 | 31 |
1 | Locked | 42 | 0 | 0 |
2 | Locked | 42 | 0 | 0 |
3 | Locked | 42 | 0 | 0 |
4 | Locked | 42 | 0 | 0 |
5 | Locked | 42 | 0 | 0 |
6 | Locked | 42 | 0 | 0 |
7 | Locked | 42 | 0 | 0 |
8 | Locked | 42 | 0 | 0 |
9 | Locked | 42 | 0 | 0 |
10 | Locked | 42 | 0 | 0 |
11 | Locked | 42 | 0 | 0 |
12 | Locked | 42 | 0 | 0 |
13 | Locked | 42 | 0 | 0 |
14 | Locked | 42 | 0 | 0 |
15 | Locked | 42 | 0 | 0 |
16 | Locked | 42 | 0 | 0 |
17 | Locked | 42 | 0 | 0 |
18 | Locked | 42 | 0 | 0 |
19 | Locked | 42 | 0 | 0 |
20 | Locked | 42 | 0 | 0 |
21 | Locked | 42 | 0 | 0 |
22 | Locked | 42 | 0 | 0 |
23 | Locked | 42 | 0 | 0 |
24 | Locked | 42 | 0 | 0 |
25 | Locked | 42 | 0 | 0 |
26 | Locked | 41 | 0 | 0 |
27 | Locked | 42 | 0 | 0 |
28 | Locked | 42 | 0 | 0 |
29 | Locked | 42 | 0 | 0 |
30 | Locked | 42 | 0 | 0 |
31 | Locked | 42 | 0 | 0 |
0 | 46200000 | 45.3 | 5120 | QAM 64 | 1 |
1 | 39400000 | 44.8 | 5120 | QAM 64 | 2 |
2 | 32600000 | 44 | 5120 | QAM 64 | 3 |
3 | 25800000 | 43.5 | 5120 | QAM 64 | 4 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
General Configuration
Allowed |
1 |
Enabled |
3.1 |
9834ncxv9873254k;fg87dsfd |
11401 |
1200000450 bps |
42600bytes |
0 bps |
Primary Upstream Service Flow
11400 |
55000270 bps |
42600bytes |
0 bps |
16320bytes |
Best Effort |
19-09-2022 22:10:22 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
19-09-2022 22:10:15 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
19-09-2022 22:10:10 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
19-09-2022 22:10:07 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
19-09-2022 22:10:05 | notice | Honoring MDD; IP provisioning mode = IPv4 |
19-09-2022 22:10:01 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
19-09-2022 22:09:57 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
19-09-2022 22:09:56 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
19-09-2022 22:09:49 | critical | Cable Modem Reboot due to power button reset |
19-09-2022 22:09:45 | critical | Cable Modem Reboot due to master console reset |
19-09-2022 22:09:44 | critical | Cable Modem Reboot due to master console reset |
18-09-2022 00:32:33 | critical | Cable Modem Reboot from SNMP |
18-09-2022 00:29:44 | critical | Cable Modem Reboot from SNMP |
18-09-2022 00:26:29 | critical | Cable Modem Reboot from SNMP |
18-09-2022 00:21:17 | critical | Cable Modem Reboot from SNMP |
18-09-2022 00:13:01 | critical | Cable Modem Reboot from SNMP |
on 20-09-2022 01:13
on 20-09-2022 18:03
on 20-09-2022 21:51
Double check all yuor cables are snug and tight without any kinks, especially the white coaxial cable.
Have you looked at Check service status at the top of the page? You can also a run a test on your equipment from there.
If nothing is showing you could also try the Service Status number 0800 561 0061. This often gives details of more local issues down to postcode level.
PS - you need to update your signature since you now have a hub 5
on 20-09-2022 22:31
on 20-09-2022 22:48
on 22-09-2022 13:22
on 24-09-2022 00:57
Finally got an engineer out, he managed to fix the upload speed/latency issue. However, if you've not seen my other post on the Networking board, I am still getting the midnight disconnections with the hub rebooting constantly for about 45 mins to an hour, happened again last night and tonight. Utter JOKE.
on 26-09-2022 09:51
Hi handsomeinked,
Thank you for your reply, I am sorry to hear you having disconnections. I have checked our services and can see there are some downstream issues, I will need to get another tech out to take a look for you.
I will pop you over a PM and get this arranged.
Zoie
on 02-10-2022 01:07
Engineer came out today. There were zero issues with the connection at the cabinet end of things, signal was perfect, to issues with cabling internally. As the reboot issues / loss of connection only started when we got the Hun 5 he has replaced the hub and flagged the old one as faulty.
Given the number of folks flagging these issues on the forums, I would suggest either there is an issue with the Hub 5 not picked up in testing or, there are a significant number of faulty units. Either way it would be amazing to actually have someone confirm what is going on and if it is a faulty batch, get them replaced quickly and without all the fuss it’s taken to get mine swapped.
Of course, only time will tell if this hub is going to do the same thing, so I am going to be keeping an eye on things. I would say a month of monitoring should give it time for the fault to show up again.
In the mean time, anyone from VM going to fess up and tell us if there is a known issue with either a batch or the whole of the Hub 5 estate!?
