Joner1998
Message 1 of 5
Broadband issues Bristol
I am based in Bristol and experiencing awful internet connections today.  The service test advices that there are no issues, is anyone else in the Bristol area experiencing problems?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 5
Re: Broadband issues Bristol
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 5
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 5
Can you please
Joner1998
Message 5 of 5
Hi Mike, thanks for your suggestions, I was out of contact for a while.  I downloaded the mobile app and it is saying that wifi is the issue rather than the connection.  I have a hub 3 and booster and still seem to have slow connection, in one of the rooms upstairs no connection whatsoever despite the booster.
I have Virgin media booster which virgin sent when I was having issues before, this did not work at all, and I purchased a netgear booster which works sometimes.
wondering if I need another solution?
