serfy
Broadband is slow and intermittent. Keep cutting out. Too much traffic from students. Sort please.
Virgin say no problems. I check with others and all affected. Waste hours on phone and service dreadful
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Broadband is slow and intermittent. Keep cutting out. Too much traffic from students. Sort please.
Then
Can you please
