psmurthw
  • 8
Message 1 of 9
Broadband dropping and slow
Sorry I am really not technical but broadband keeps losing connection and is slower than I expect. We should have 100mbp but are lucky if it gets to 40. When I have my echo device on it keeps disconnecting. Have tried pressing the reset button on the router and leaving off for 10 minutes every now and then. Not sure what to try next. We also have a booster.
Can anyone help please?
TIA
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 9
Re: Broadband dropping and slow
Which Hub do you have ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
psmurthw
  • 8
Message 3 of 9
Hello
Thanks for taking an interest.  I turned it off for 10 minutes and reset. It went up to 44.2 and 9.14
I have just connected direct with a cable and now it's:
21 ping
61.39 download
10.08 upload.
It's a Hob 3.0
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 9
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 9
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 9
Can you please
psmurthw
  • 8
Message 7 of 9
My BQM
psmurthw
  • 8
Message 8 of 9
Hello again
I've managed to set up the monitor and attach the link as suggested.
I can't check the router status as below because it asks me to put the router password in and there isn't an option to check status.
It is a hub 3.0  I did try and put the router password in but it said it was incorrect.(It isn't incorrect.  I double checked a couple of times!)
Perhaps I should give it until tomorrow and then take a look at the monitor?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 9
Try logging in to the Hub settings again, make sure you use the Settings Password, you will need to set language preference etc.
You can then log out and follow the instructions from above.
Hub-3-Password
