pkquinton
  • 12
Message 1 of 34
Broadband cutting out
Hello. This is my first post. Grateful for any help. I'm not very IT literate, so please be patient and talk to me like I am your nan.
Me and my wife are working from home (we're both key workers), and our son is home schooling. We will have up to 8 devices at any one time connected to our SuperHub 3 (HP Elitebook, MacBook Air, Acer Chromebook, and 5x iPhones), and are on the M200 broadband package.
I think our internet speed is generally fine and the wifi signal is strong in most rooms, but our broadband has been cutting out several times a day for the past 2-3 weeks and is getting worse. This is a causing us real problems as we end up being disconnected from conference calls, VPNs, Google Classroom, etc, and means we are unable to work for periods of time.
I have run several tests on the router, rebooted it, checked the cables, etc. It's also well positioned. I think the issue is with the broadband signal coming into our house (in Kingston Upon Thames). I see there is area problem just at the moment, but the signal cutting out is an ongoing problem, which has been particularly bad today.
Very grateful for any help as I cannot find a number on the website to call Virgin Media direct.
Finally, would it help if I...
1. Upgraded to a faster broadband package? (That said, I cannot see online that this is possible without also upgrading by TV package, which I don't want or need.)
2. Invested in a mesh router? (Not that I know what a one is, but I was researching solutions online and looked like it might help.)
Thank you for any help. Cheers.
Kippies
  • 12.44K
  • 859
  • 3.72K
Message 2 of 34
Re: Broadband cutting out
Lets start at the start- check the signal coming in.
Go to 192.168.0.1 in your browser, or 192.168.100.1 if in modem mode
Do NOT LOG IN
Post your upstream, downstream and network metrics from your HUB.
Screen captures are nice, C&P will do though.
Someone will get a look for you.
pkquinton
  • 12
Message 3 of 34
The upstream screenScreen Shot 2020-04-25 at 12.39.42.pngcap
pkquinton
  • 12
Message 4 of 34
The network log screencaps (lots of warnings and criticals)
pkquinton
  • 12
Message 5 of 34
Having problems inserting photos. Will try again later.
pkquinton
  • 12
Message 6 of 34
Network log screencaps
Screen Shot 2020-04-25 at 12.41.02.jpgScreen Shot 2020-04-25 at 12.41.15.jpgScreen Shot 2020-04-25 at 12.41.33.jpgScreen Shot 2020-04-25 at 12.41.47.jpg
pkquinton
  • 12
Message 7 of 34
Downstream screencaps
Screen Shot 2020-04-25 at 13.05.49.pngScreen Shot 2020-04-25 at 13.06.02.pngScreen Shot 2020-04-25 at 13.06.14.pngScreen Shot 2020-04-25 at 13.06.26.pngScreen Shot 2020-04-25 at 13.06.37.png
Kippies
  • 12.44K
  • 859
  • 3.72K
Message 8 of 34
Yeah most stuff is out of spec.
Ill flag for staff to pick it up for you.
You will likely need an engineer out, which will be arranged through here for you.
pkquinton
  • 12
Message 9 of 34
Thank you. I can't post the network logs screencaps as they apparently contain my MAC address (whatever that is), but they do show a string of messages like "Warning! RCS partial service" and "Critical! SYNC Timing Synchronization Failure".
I'm v grateful for your help. Cheers.
Joe1888cfc
  • 14
Message 10 of 34
