MarkhamFam
Broadband consistently low
We have a Hub 3.0.
We’re currently experience a large number of outages throughout the day! We have had engineers out who have had a look made small changes and the internet picked up. Shortly after though, further outages reoccur.
We should be getting a download speed of 200Mbs and an upload speed of 20Mbs.
On average we receive 50mbs download and 14mbs upload.
There are a number of occasions when doing a speed test that it can’t do it because it states we’re not connected to the internet.
We’re regularly having to turn the box on and off or reboot.
Recently we had a download speed of 0.09mbs and 6.95 upload.
Really upset that after having a couple of engineers and raising this issue with Virgin for months it hasn’t changed. We rarely get the speed we should.
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Broadband consistently low
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
The sooner the better …
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
