hethers_
  • 5
Message 1 of 7
Broadband Upgrade issues
On Tuesday I upgraded my broadband package from 50 to M350. yesterday I had speeds of 100.
I have tried the pin hole reset trick, this morning I got 350+ speeds. Now at 1pm I have speeds of 7..
I have tested on the speed checker website on many devices standing next to router they all provide the same results as below 20. I have checked the rooms for black spots on the app and the app states my router is great?
On the telephone I'm on hold for 30 mins+. Cannot reach anyone to speak to.
Any advice on what to do next?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 7
Re: Broadband Upgrade issues
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 7
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
hethers_
  • 5
Message 4 of 7
DownStream
13310000005.540256 qam25
2203000000540256 qam9
3211000000540256 qam10
42190000004.538256 qam11
52270000004.640256 qam12
62350000004.638256 qam13
72430000004.639256 qam14
82510000004.338256 qam15
9259000000438256 qam16
102670000004.338256 qam17
112750000004.540256 qam18
122830000004.838256 qam19
13291000000538256 qam20
14299000000540256 qam21
15307000000538256 qam22
163150000005.440256 qam23
173230000005.438256 qam24
183390000004.838256 qam26
193470000004.538256 qam27
20355000000538256 qam28
213630000005.138256 qam29
223710000005.338256 qam30
233790000005.438256 qam31
243870000004.538256 qam32
1Locked40.360
2Locked40.390
3Locked40.350
4Locked38.940
5Locked40.350
6Locked38.950
7Locked39.880
8Locked38.910
9Locked38.950
10Locked38.650
11Locked40.350
12Locked38.960
13Locked38.950
14Locked40.950
15Locked38.670
16Locked40.350
17Locked38.950
18Locked38.610
19Locked38.910
20Locked38.950
21Locked38.650
22Locked38.960
23Locked38.960
24Locked38.900
hethers_
  • 5
Message 5 of 7
16029997942.8512064 qam1
23939999840.8512064 qam4
34619997442.8512064 qam3
45369998842.8512064 qam2
2ATDMA0010
3ATDMA0000
4ATDMA0000
hethers_
  • 5
Message 6 of 7
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
ldJKDHSUBsgvca69834ncxv98
SFID552
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID551
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
hethers_
  • 5
Message 7 of 7
14/01/2021 13:04:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 13:04:5Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 09:37:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 23:21:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 22:46:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 22:43:21Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 18:54:24noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 18:54:17Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 18:52:30noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 18:51:58Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 11:57:56noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt022-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 11:57:56ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 16:57:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 15:51:56noticeSW download Successful - Via Config file
08/01/2021 15:49:47noticeSW Download INIT - Via Config file
01/01/1970 00:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 15:45:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 13:29:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
