Davies6882
Message 1 of 10
Broadband Speen no where nere minimum standard
We are paying for 200mb broadband but only achieving around 50mb over WiFi and 85mb when plugged directly into the router on modem mode. This is well below the minimum standard, let alone the 200mb expected
gary_dexter
  • 28.9K
  • 1.76K
  • 3.78K
Message 2 of 10
Re: Broadband Speen no where nere minimum standard
What device are you Speedtesting with?
SCA1972
  • 5.73K
  • 652
  • 1.92K
Message 3 of 10
@Davies6882 A couple of your images had to be rejected to protect your privacy as they contained your WAN IP address.  Speedtest have a share option that allows you to share test results without revealing your IP address.
The hub stat screen shots are very small and hard to read, but I don't think there is anything wrong with the figures posted so far.
To echo Gary, what devices are you using to test?  50Mbps is a common top speed for some wireless devices that can only use the 2.4GHz band and 85Mbps is a common top speed for Ethernet adapters that are not gigabit ones or a faulty Ethernet cable can limit speeds.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Davies6882
Message 4 of 10
Hi a have tried on several tablets/ipads/mobile phones for the WiFi test and never got a reading above 65mb and on my laptop (the only device I can actually directly wire into the router)
I have the virgin 2ac router in modem mode connected to a 300mbps WiFi router via ethernet cable. I am using the ethernet cable that the virgin media technician installed when it was set up 2 years ago.
gary_dexter
  • 28.9K
  • 1.76K
  • 3.78K
Message 5 of 10
As the router is only 300Mbps wireless I’m guessing the Ethernet ports are only 100Mbps ports and not gigabit ports.
If you remove the router and wire direct to the hub what speed do you get?
Davies6882
Message 6 of 10
Absolutely none, for some reason my laptop cannot even connect to the Internet if I put it straight into the virgin box, it just keeps saying connected but no internet. I have just checked and the router is actually 600mbps and not 300mbps but the ports are only 100mbps max. I am running the WiFi speed tests on my p30 Pro mobile which has WiFi speeds of up to 1.7gb so should be able to achieve speeds higher than 50-60mb
SCA1972
  • 5.73K
  • 652
  • 1.92K
Message 7 of 10
Was the hub still in modem mode with your router plugged in when you plugged in the laptop?  Only one Ethernet port is active in modem mode and if your router was already plugged in it would have the only active port on the hub.  If you only had the laptop plugged in, did you try rebooting the hub while the laptop was plugged in?
What speed is the WAN port on your router? If it is also 100Mbs (I suspect it is) then that will limit the speed that your router can get from the hub and by extension limit your wireless speeds via your router.
The speeds you are quoting for both your phone and router are theoretical speeds that are much higher than can be achieved in the real world.  The SH2ac in router mode should be capable of faster WiFi speeds but we have no idea the specs of your router.  Maybe post the make and model of your router and we can look it up and advise it is capable of the speed you want.
VM staff will not accept speed test via third party equipment so a test with the hub in router mode might be a good idea.
My money is on your kit being the bottleneck.
Scott
Davies6882
Message 8 of 10
Thank you for your help.
I have just checked the wan speed on the router and it does indeed state 100mbps. So I'm guessing that is the max I can expect. If I get a router that has a gb WAN, should I expect closer to the 200mbps that I should be getting?
  • 20.51K
  • 2.18K
  • 3.62K
Message 9 of 10
Yes
Get some new good quality Cat6 cables too - they have better electrical shielding.
SCA1972
  • 5.73K
  • 652
  • 1.92K
Message 10 of 10
As long as you get one with all gigabit ports (not just the WAN port) then you should get 200Mbps via Ethernet.  Or you could just use the gigabit ports on the VM hub in router mode, no?
I'm not a big fan of their hubs myself but they usually do the job with wired connections at least.
Scott
