GM1875
  • 17
Message 1 of 32
Broadband Speed
Hoping you can help with this.
I have the 350mbs broadband package, but am not getting anywhere near these speeds. Struggle to get above 50mbs.
I've tried to log into my Hub on the http://192.168.0.1/ URL, but when I put in my router password it's not recognised. Not sure why this is?
I've rebooted my router numerous times now, and paused all the devices that are connected (apart from my iPhone) and it made no difference to the speed i'm getting.
Not sure if there's a fault with my line, but what can I do to get the broadband speed I'm paying for?
Gordon Marshal
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 32
Re: Broadband Speed
Firstly the Hub log in.
Make sure you are using the Settings password ...
Hub-3-Password
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 32
Re: Broadband Speed
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
GM1875
  • 17
Message 4 of 32
Re: Broadband Speed
Thanks Mike. That fixed it.
GM1875
  • 17
Message 5 of 32
Re: Broadband Speed
With everything paused and laptop connected via cable I'm getting 87.62mbs download, 37.17 upload. Much better, but well short of the 350mbs.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 32
Re: Broadband Speed
Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed' as for the cable connected device you used for the speed test?
GM1875
  • 17
Message 7 of 32
Re: Broadband Speed
1000mbps connected via cable, which is the same for all other devices connected wirelessly.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 32
Re: Broadband Speed
Can you put the laptop into 'Safe Mode with Networking' and do a couple more tests at speedtest.net please.
GM1875
  • 17
Message 9 of 32
Re: Broadband Speed
in safe mode and networking, cable to hub, only two devices connected and getting 88.17 download and 37.03 upload on Speedtest
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 32
Re: Broadband Speed
What are the two devices connected ?
