Rarebob
Message 1 of 5
Broadband Speed
I have complained now a number of time in relation to my very poor broadband speed. I have not recieved any response. I completed a speed test again today using your suggested provider these are the readings - I am on the M200 Contract.
Ping 27 ms
Download 12.35 mbps
Upload - 20.83 mbps
I think it is quite obvious which is worryingly low. This has been the speeds since installation in June. I would very much appreciate some help. I have moved the PC into the front room and plug it in with cable and still didn't get the promised minimum speed. I have also followed suggested points to ensuring better wifi and still no improvement.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 5
Re: Broadband Speed
Which Hub do you have ?
Are you testing with Wi-Fi or ethernet cable connected device ?
Rarebob
Message 3 of 5
Re: Broadband Speed
Hi Mike,
I believe the page is Ookla that Virgin Speed test sends you to. I have also taken the PC downstairs and plugged it into the Hub 3 with ethernet got download of 75 mbps. Also It is just a broadband package. The TV is plugged in directly to the hub and that still takes time to load on Netflix or Amazon Prime.
SCA1972
  • 5.91K
  • 662
  • 2.02K
Message 4 of 5
Re: Broadband Speed
For a wired connection, speeds below 100Mbps per second as you describe are often the result of a hardware limitation. Some PC's have network cards that are limited to 100Mbs, or faulty drivers that can limit speed or are not configured correctly, or it could be the Ethernet cable that is limited to 100Mbs by design or is damaged.
______________________
Scott
My setup: VM TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Buffer6
  • 11.68K
  • 93
  • 639
Hero
Message 5 of 5
Re: Broadband Speed
You can check your device connection speed if you login to your Hub
  http://192.168.0.1/  in router mode or http://192.168.100.1/ in modem mode
Click on devices connected this will show the speed you are connected to the
Hub, if it says 100Mbps then your speed will not exceed 100Mbps usually a lot less.
to get speeds in excess of 100Mbps it should read 1000Mbps. Some older
equipment is not equipped with a Gigabit NIC (Network Interface Card)
However, there is a workaround if you use an external USB3 Gigabit card
