paddyslate
Message 1 of 9
Broadband Speed
Hi guys. My broadband speed is 38mbps when I should have 100mbps. I have rebooted, relocated and checked the connections to my router. I have used speedtest.net to determine the speed. I'm sitting here waiting on a reply to my web-chat and have been so for nearly one hour. Anyone have any ideas?
Pat
Anonymous
Not applicable
Message 2 of 9
Re: Broadband Speed
wireless?
paddyslate
Message 3 of 9
Re: Broadband Speed
yes.
paddyslate
Message 4 of 9
Re: Broadband Speed
Just checked with an ethernet cable connection and it is also 38mbps.
Anonymous
Not applicable
Message 5 of 9
Re: Broadband Speed
sounds like your wireless device then. You need a 802.11AC device on 5ghz to get anywhere near the max speed.
Also the hub wifi is an entry device. you can get better wireless routers
paddyslate
Message 6 of 9
Re: Broadband Speed
Thanks for that. When you say wireless device, do you mean the VM router?
  • 22.45K
  • 2.4K
  • 4K
Message 7 of 9
Re: Broadband Speed
Was that with the Hub in modem mode and thus your device being the only one connected?
If it was - then boot it into safe+networking mode and try again - at speedtest.net to your nearest VM server on 2 browsers.
See what those options get.
Anonymous
Not applicable
Message 8 of 9
Re: Broadband Speed
no your device you are using. What wireless card is it in
Anonymous
Not applicable
Message 9 of 9
Re: Broadband Speed
ignore me i read your wired test as 308 for some reason 🙂
