Paul_B1968
Broadband Speed slow
Hello,
My broadband speed has been getting slower over the weeks and now its more-or-less unusable for Teams etc (I pay for 200MB Fibre).
I ran three tests today and below was the best (laptop into router with wired connection, all other devices physically switched off). Time of test approx 15:00 today.
Could someone investigate please.
conman33158
  • 1.4K
  • 120
  • 255
Knows their stuff
Re: Broadband Speed slow
Are you testing wired or wireless?
What speed do you get on https://speedtest.samknows.com/ with direct wired connection from PC/Laptop to router using a Cat 5e cable or better with a 1Gbps capable Ethernet network card?
  1. Make sure the cable is Cat 5e or better
  2. Make sure your PC/laptop has a 1Gbps or better network card
  3. Disconnect all other Ethernet cables when running the test
Ayisha_B
  • 681
  • 19
  • 68
Hi @Paul_B1968,
Welcome to our Community Forums and thank you for posting.
Sorry to hear you are having issues with slow broadband speeds- that doesn't look great at all.
I've had a quick peek at the account and there's no area outage that could be causing this.
I do note however that your hub was last rebooted 34 days ago. We do recommend a frequent reboot which will allow your connection to refresh and the devices to hop onto the least congested channels. Are you able to do this now and let me know if you notice any difference?
I can also see that some of the WiFi devices are very close to the Hub and could be wasting valuable WiFi bandwidth. Connecting them via Ethernet could improve things for other WiFi devices.
Ayisha_B
