briandonnelly06
Settling in
Broadband Speed Poor
Hi Team
My broadband speed has been consistently slow for a long time now, I have only recently started keeping track of this in speedtest.net, but i should be getting 200 Mb p/s as per my contract, I am seeing no better than 88 Mb p/s even after following all troubleshooting guides and carrying out reboots etc.
Brian
14190000003.440256 qam32
22030000001.740256 qam9
32110000001.740256 qam10
42190000001.740256 qam11
52270000001.740256 qam12
62350000001.740256 qam13
72430000001.740256 qam14
82510000001.740256 qam15
92590000001.740256 qam16
10267000000240256 qam17
11275000000240256 qam18
122830000002.240256 qam19
132910000002.540256 qam20
142990000002.740256 qam21
153070000002.440256 qam22
163150000002.540256 qam23
173230000002.740256 qam24
183310000002.940256 qam25
19371000000340256 qam26
203790000003.240256 qam27
213870000003.540256 qam28
223950000003.540256 qam29
234030000003.540256 qam30
244110000003.440256 qam31
1Locked40.370
2Locked40.340
3Locked40.350
4Locked40.360
5Locked40.350
6Locked40.330
7Locked40.900
8Locked40.900
9Locked40.300
10Locked40.350
11Locked40.350
12Locked40.360
13Locked40.360
14Locked40.340
15Locked40.950
16Locked40.950
17Locked40.340
18Locked40.3120
19Locked40.350
20Locked40.350
21Locked40.360
22Locked40.350
23Locked40.360
24Locked40.350
Refresh dataUpstream bonded channels
1461999834.6512064 qam11
2325999814.6512064 qam13
3393999964.6512064 qam12
4536999964.6512064 qam10
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
briandonnelly06
Settling in
Re: Broadband Speed Poor
08/10/2020 18:29:14noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 18:27:24Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/10/2020 17:03:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/10/2020 02:29:44noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/10/2020 02:29:44ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 15:23:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 14:29:43noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 14:29:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 07:12:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/09/2020 04:33:42noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/09/2020 04:33:42ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 02:13:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 21:57:8noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/09/2020 21:57:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/09/2020 00:00:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 09:57:9noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/09/2020 09:57:9ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 22:51:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 21:57:8noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/09/2020 21:57:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
88Mbs is indicative of either an iffy ethernet cable or a Network Interface Card (NIC) at the wrong setting.
Log into the Hub settings then connected devices and see what speed is indicated for your device.
briandonnelly06
Settling in
124.47 - does seem to be device specific as running a speedtest on my mobile connected to the hub give me over 200 Mb a sec, it's on 2.4 GHz WiFi
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
What speed do you get at >> Ookla << using a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
briandonnelly06
Settling in
210 Mbps - must be the WiFi card that is the bottleneck, my computer sits close enough to my router that I can keep them connected this way, thanks for the help with this 🙂
