JDBarnes761
Message 1 of 8
Broadband Speed Lock - Channels
Hi All,
Any one can help with the Speed issue i am having with my Broadband, I am getting Locked Channels on my router and the Customer Services doesn't help one bit
Screenshot 2022-06-06 at 10.23.40.pngScreenshot 2022-06-06 at 10.23.33.pngScreenshot 2022-06-06 at 10.23.09.png
-tony-
  • 19.22K
  • 1.46K
  • 3.76K
Message 2 of 8
Re: Broadband Speed Lock - Channels
that looks ok afaik - looks like a hub3 so cannot check everything - why do you think thats a problem
post the upstream settings
and what problem do you have - speed? - wird or wifi - always test with a wired connection
____________________
Tony.
Sacked VIP
gitty
  • 257
  • 67
Superfast
Message 3 of 8
"Locked" is good. It means the channel has been assigned to the modem and is working. 🙂
JDBarnes761
Message 4 of 8
Both Wifi and Wired and i have the Wifi Pods in but it seems that the router keeps losing the connection and i am not sure if it is something to do with the 4db adapter on my router.
I also get an issue with the router saying there is a problem with the wifi but not sure what is happening with it, this is from the network diagnostics tool
JDBarnes761
Message 5 of 8
Thats fine, thanks you for clearing that pair up but having the issues everyday where i need to reset the router but I am in two minds to buy a Gaming Router to replace this one
JDBarnes761
Message 6 of 8
Could this also be because of the router being the Super Hub 3 and not the Hub 4 or 5
-tony-
  • 19.22K
  • 1.46K
  • 3.76K
Message 7 of 8
upstream is fine - the attenuator should make no difference to the stability of the line
nothing wrong with the hub3 against the 4 - the 5 is still in test mode - soft release VM call it or something like that- no idea what that means but its a long way from the finished article
if you are getting slow speeds and drops on wired then adding a 3rd party router is unlikely to solve that as its would suggest a line fault - set up a BQM
leave it 24 hours to populate and post a link
Tony.
Sacked VIP
Ayisha_B
  • 4.46K
  • 174
  • 396
Message 8 of 8
Hi @JDBarnes761,
Welcome to our Community Forums and thanks for your post.
Sorry to hear you've had some issues with the service. All checks have been done this end and no issues found.
How have things been since posting?
If no change, please do set up a BQM as suggested by Tony. This will continually monitor the state of your connection and record any network dropouts.  It does it 24/7/365 and it keeps a visual record of your connection. We advise to keep it running for around 24-48 hours to gather enough data. You can then post a link to your live BQM on this thread and we can check for any disconnections or drop out you advise you're experiencing.
Many thanks
Ayisha_B
