NMJToolbox
  • 153
  • 7
  • 44
Superfast
Message 1 of 34
Broadband Speed Dropped over the past week or so
I am currently on the 350mbps package and was fairly happy with the speeds I was getting a few months ago, I was generally getting around the speed I should be and sometimes more.  However, the last week or so the speed has dropped.  Not enough to be unusable but almost as bad as downgrading to the next tier down.  I am currently averaging 180-250mbit.
13310000001.740256 qam25
2203000000340256 qam9
32110000002.740256 qam10
42190000002.540256 qam11
52270000002.540256 qam12
6235000000340256 qam13
72430000002.940256 qam14
82510000002.540256 qam15
92590000002.540256 qam16
102670000002.540256 qam17
112750000002.740256 qam18
122830000002.240256 qam19
132910000002.440256 qam20
14299000000240256 qam21
153070000002.440256 qam22
16315000000240256 qam23
17323000000238256 qam24
18339000000240256 qam26
193470000001.440256 qam27
203550000001.740256 qam28
213630000001.240256 qam29
223710000001.740256 qam30
233790000001.240256 qam31
243870000001.540256 qam32
1Locked40.900
2Locked40.350
3Locked40.950
4Locked40.360
5Locked40.350
6Locked40.340
7Locked40.350
8Locked40.300
9Locked40.950
10Locked40.360
11Locked40.340
12Locked40.350
13Locked40.340
14Locked38.960
15Locked40.350
16Locked40.300
17Locked38.950
18Locked40.350
19Locked40.300
20Locked40.370
21Locked40.300
22Locked40.950
23Locked40.300
24Locked40.300
1462000094.925512016 qam1
2258000294.725512016 qam4
3325999984.775512016 qam3
4393999834.925512016 qam2
3ATDMA0000
4ATDMA0000
S60 Area 14
Utilisation Fault: F006248376
Fix: 01/06/2018 - missed
Fix: 27/06/2018 - Fixed 9/6/18
Anonymous
Not applicable
Message 2 of 34
Re: Broadband Speed Dropped over the past week or so
All of your upstream channels are out of spec (16 QAM when they should be 64 QAM):
Power levels are also quite high.
VM need to investigate further.
Alex_RM
  • 4.28K
  • 247
  • 325
Message 3 of 34
Hi NMJToolbox,
Thanks for posting, and sorry to hear you're getting some slow speeds.
Can you confirm if this is on a wired or wireless connection?
I can also see it's been a few days since your last reboot, if you can please do this for me and I'll check the hubs levels again.
Alex_Rm
NMJToolbox
  • 153
  • 7
  • 44
Superfast
Message 4 of 34
Hi Alex,
This is both wired and wireless.  The stats posted above were immediately after a reboot - no change.
S60 Area 14
Alex_RM
  • 4.28K
  • 247
  • 325
Message 5 of 34
Thanks for confirming 🙂
I appreciate the hub was rebooted on Saturday, but if you could please reboot today also so we can see if there is any change in the hubs levels.
Alex_Rm
NMJToolbox
  • 153
  • 7
  • 44
Superfast
Message 6 of 34
Rebooted, here you go:
13310000001.240256 qam25
22030000002.540256 qam9
32110000002.440256 qam10
42190000002.240256 qam11
52270000002.240256 qam12
62350000002.540256 qam13
72430000002.440256 qam14
8251000000240256 qam15
9259000000240256 qam16
10267000000240256 qam17
112750000002.240256 qam18
122830000001.940256 qam19
132910000001.940256 qam20
142990000001.739256 qam21
15307000000240256 qam22
163150000001.540256 qam23
173230000001.738256 qam24
183390000001.540256 qam26
193470000000.940256 qam27
203550000001.240256 qam28
213630000000.940256 qam29
223710000001.240256 qam30
233790000000.738256 qam31
243870000001.240256 qam32
1Locked40.300
2Locked40.950
3Locked40.940
4Locked40.300
5Locked40.350
6Locked40.350
7Locked40.900
8Locked40.300
9Locked40.300
10Locked40.300
11Locked40.350
12Locked40.900
13Locked40.350
14Locked39.300
15Locked40.350
16Locked40.900
17Locked38.950
18Locked40.340
19Locked40.300
20Locked40.300
21Locked40.300
22Locked40.350
23Locked38.900
24Locked40.300
1461999664.925512016 qam1
2258000094.775512016 qam4
3326000094.925512016 qam3
4393999864.925512016 qam2
3ATDMA0000
4ATDMA0000
S60 Area 14
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 34
NMJToolbox
  • 153
  • 7
  • 44
Superfast
Message 8 of 34
The BQM for me (superhub in modem mode with synology 2600AC router) seems a bit tempremental.  It was fine until last saturday and then the BQM went completely red as though the BQM could not get ping responses.  I have no idea why as I have not changed anything.  Anyway, here is a link to BQM:
BQM
S60 Area 14
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 34
Your WAN IP may have changed, check the IP on the BQM against the current IP.
Check your router settings for ICMP permissions, the router may have updated in the background.
NMJToolbox
  • 153
  • 7
  • 44
Superfast
Message 10 of 34
WAN IP is correct on BQM, Synology firewall ICMP is set to allow on all ports from all IPs.
S60 Area 14
