08-09-2021 07:41 - edited 08-09-2021 07:47
I hope this is the right information:
Acquired Downstream Channel (Hz) | 234750000 | Locked |
Ranged Upstream Channel (Hz) | 25799972 | Locked |
Provisioning State | Online |
1 | 234750000 | -3.2 | 30 | 256 qam | 13 |
2 | 242750000 | -4 | 30 | 256 qam | 14 |
3 | 250750000 | -4.9 | 31 | 256 qam | 15 |
4 | 258750000 | -5.2 | 30 | 256 qam | 16 |
5 | 266750000 | -5.2 | 30 | 256 qam | 17 |
6 | 274750000 | -5.4 | 32 | 256 qam | 18 |
7 | 282750000 | -4.9 | 31 | 256 qam | 19 |
8 | 290750000 | -4.2 | 32 | 256 qam | 20 |
9 | 298750000 | -3.7 | 33 | 256 qam | 21 |
10 | 306750000 | -4 | 33 | 256 qam | 22 |
11 | 314750000 | -5 | 33 | 256 qam | 23 |
12 | 322750000 | -5.5 | 32 | 256 qam | 24 |
13 | 330750000 | -5.7 | 32 | 256 qam | 25 |
14 | 338750000 | -6.4 | 32 | 256 qam | 26 |
15 | 346750000 | -6.4 | 32 | 256 qam | 27 |
16 | 354750000 | -5.9 | 33 | 256 qam | 28 |
17 | 362750000 | -5 | 32 | 256 qam | 29 |
18 | 370750000 | -4.5 | 33 | 256 qam | 30 |
19 | 378750000 | -4 | 33 | 256 qam | 31 |
20 | 386750000 | -4 | 32 | 256 qam | 32 |
21 | 394750000 | -4.2 | 31 | 256 qam | 34 |
22 | 402750000 | -4.7 | 32 | 256 qam | 35 |
23 | 410750000 | -5.2 | 32 | 256 qam | 36 |
24 | 418750000 | -6 | 32 | 256 qam | 37 |
1 | Locked | 30.7 | 1506934354 | 231820808 |
2 | Locked | 30.4 | 182831611 | 124254687 |
3 | Locked | 31 | -728123307 | 24605376 |
4 | Locked | 30.8 | -692838222 | 74568452 |
5 | Locked | 30.9 | -1441922497 | 196423709 |
6 | Locked | 32.3 | -1080006260 | 272895856 |
7 | Locked | 31.9 | -1710995096 | 123928878 |
8 | Locked | 32.9 | -1590059732 | 93709778 |
9 | Locked | 33.3 | -1958562167 | 60954973 |
10 | Locked | 33.3 | 2067948166 | 33030925 |
11 | Locked | 33.4 | 979365257 | 7986828 |
12 | Locked | 32.9 | 111551489 | 1203281 |
13 | Locked | 32.6 | -196013008 | 2727361 |
14 | Locked | 32.6 | -555097794 | 4013337 |
15 | Locked | 33 | 1130532303 | 130666 |
16 | Locked | 33 | 470090598 | 110901 |
17 | Locked | 32.6 | 365863921 | 110750 |
18 | Locked | 33.4 | 330481245 | 114606 |
19 | Locked | 32.9 | 385382864 | 111465 |
20 | Locked | 32.5 | 590684338 | 167234 |
21 | Locked | 31.9 | 1481476873 | 139340 |
22 | Locked | 32.6 | 896672730 | 110459 |
23 | Locked | 32.5 | 1278222870 | 345098 |
24 | Locked | 32.3 | 2077091169 | 195625 |
1 | 25799972 | 51 | 5120 | 64 qam | 4 |
2 | 46200723 | 51 | 5120 | 64 qam | 1 |
3 | 39399300 | 49.8 | 5120 | 64 qam | 2 |
4 | 32599983 | 49.5 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 88 | 0 |
2 | ATDMA | 0 | 0 | 73 | 0 |
3 | ATDMA | 0 | 0 | 90 | 0 |
4 | ATDMA | 0 | 0 | 91 | 0 |
Continued in next post
08-09-2021 07:44 - edited 08-09-2021 07:46
Continued....
General Configuration
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt057-b.cm |
SFID | 135140 |
Max Traffic Rate | 115000000 |
Max Traffic Burst | 10000 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 135139 |
Max Traffic Rate | 10500047 |
Max Traffic Burst | 16320 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
08/09/2021 06:12:14 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 06:04:38 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 06:04:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:58:14 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:58:9 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:57:22 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:56:27 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:53:42 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:53:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:51:59 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:51:59 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:51:59 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:51:53 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:51:53 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:46:7 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:45:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:42:55 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:42:37 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:36:31 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/09/2021 05:33:7 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
I'm using a Windows 10 laptop with 8GB Ram, 500GB SSD, fully updated.
VM recommended speed test shows this:
on 08-09-2021 08:05
on 11-09-2021 10:47
Hi JordanJ,
Thanks for your post and apologies to hear that you are having an issue with your broadband dropping out.
Taking a look at things at this end, there appears to be a pro longed signal level issue. We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you.
I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a private message regarding this. Just click on the little plum envelope at the top right hand side of the page to access your inbox.
on 12-09-2021 11:28
Hi JordanJ,
Thanks for coming back to via private message.
I have booked you in for the next available appointment. We cannot confirm the appointment time slot, so to view this please sign in to My Virgin Media here: My VM Just go to My Account > Track your orders.
Please ensure that someone over the age of 18 is at the property for the time the engineer is there.
If the appointment is unsuitable or if anyone living at your property has tested positive for Coronavirus, has been asked to self-isolate or has flu-like symptoms then please reschedule the appointment on the same link.
Lets us know how the appointment goes.
Take care.
on 12-09-2021 16:10
What a gem! Thank you for your help!
on 16-09-2021 05:53
All fixed and running again!
How do I contact VM to let them know how nice the guy was?
on 16-09-2021 07:13
on 16-09-2021 10:50
Link?
on 18-09-2021 11:15
Glad to hear the issue was resolved @JordanJ.
To send appreciation to our staff, you can make a post here as you have done prior and we will pass this on to the relevant person or team.
