MichaelSimpson
  • 19
Message 1 of 22
Broadband Configuration Not Applied by VM
Upgraded to M500 via the oompf bundle and VM still haven't applied the increased parameter settings to reflect the increase in broadband service sold to us. I have called several times to be told allow some time, hard reset superhub-3 etc. The data pulled from the system is still showing the old settings so VM have not applied the increased parameters to allow the faster speeds. Customer service don't seem to understand and no one is available to check the settings applied to our package.
Could someone from VM technical be so kind as to look into this for us and PM me please?
No issues with equipment etc:
  • Superhub-3 in modem mode (with M350 settings still applied)
  • Netgear nighthawk R8000 (shows 300Mb/s at source)
  • Testing speeds via Router direct, hard wire CAT6 in PC and via high speed mobile device
I am not an expert but as the values and settings haven't changed i assume the settings and configuration haven't been arranged and applied by VM.
Thanks for your help.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 22
Re: Broadband Configuration Not Applied by VM
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Configuration tab onto here, if you get a yellow / straw box warning click the Post button again.
Buffer6
  • 11.12K
  • 93
  • 628
Hero
Message 3 of 22
It can take up to 48hrs for a new config to come through
And some areas are still limited to M350 or M200 packages
They are not set up for higher speeds as yet.
MichaelSimpson
  • 19
Message 4 of 22
I'll give it another day or two then. Our area should be fine for M600, that's what i am told, fingers crossed.
MichaelSimpson
  • 19
Message 5 of 22
Item Status Comments
419000000
Locked
Ranged Upstream Channel (Hz)
60299993
Locked
Provisioning State
Online
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SUBsgvca69834ncxv9873254k;fg8
SFID13769
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID13298
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
MichaelSimpson
  • 19
Message 6 of 22
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 22
Your Hub is definitely configured for the 500Mbs service.
SFID13769
Min Traffic Rate0
SFID13298
Min Traffic Rate0
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 22
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MichaelSimpson
  • 19
Message 9 of 22
Hello,
PING ms 9
DOWNLOAD Mbps 312.97
UPLOAD Mbps 36.83
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 22
Please post a 'Live Link' to your BQM on here.
