drdan1974
Broadband 500 provides no more than 170 or 200
Dear all how shall I improve my speed as 500 M has never been reached on my home.i have tried all the advice from virgin website and no one came back with other efficient solution.
How can I sort this out?
I have called the tech team but never came back
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Broadband 500 provides no more than 170 or 200
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
