rickym68
Message 1 of 7
Bandwidth Throttling
Bandwidth is throttled from 200Mbps to 2Mbps and I'm told it will take 30 days to resolve.
There is nothing wrong with my line and I know I'm being throttled, why?
30 days isn't acceptable, I'm working from home and so is my daughter at the moment. Had to give her access to my mobile data earlier!
Does anyone know how I can get this sorted? I've tried calling twice.
Thank you,
Ricky
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 7
Re: Bandwidth Throttling
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 7
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
rickym68
Message 4 of 7
Here's all the stream information.
And the Live Graph
Thank You!
Ricky
Down Stream
330750000
Locked
Ranged Upstream Channel (Hz)
46200000
Locked
Provisioning State
Online
14620000042512064 qam2
25370000043.8512064 qam1
33940000042512064 qam3
43260000041.3512064 qam4
2ATDMA0010
3ATDMA0010
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID678296
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID678295
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling Type
BestEffort
rickym68
Message 5 of 7
Looks like its been fixed!
Hope it stays this way as I've had no confirmation from Virgin Media.
Speed Tests
  Date Down HTTPx6 Down HTTPx1 Upstream IP Address ISP
  Wed 09/12/2020 08:37 202.47 Mbps 193.25 Mbps 21.20 Mbps [MOD EDIT: Personal info removed] Virgin Media
  Tue 08/12/2020 19:23 1.36 Mbps 0.85 Mbps 0.33 Mbps [MOD EDIT: Personal info removed] Virgin Media
  Tue 08/12/2020 13:52 1.79 Mbps 2.00 Mbps 0.41 Mbps [MOD EDIT: Personal info removed] Virgin Media
  Mon 07/12/2020 14:53 1.82 Mbps 2.00 Mbps 0.41 Mbps [MOD EDIT: Personal info removed] Virgin Media
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 7
Can you repost your Hub Data please.
rickym68
Message 7 of 7
the only thing that has really changed is the full down stream data, which is probably why its working again...
thanks,
ricky
13307500002.940256 qam25
22347500003.540256 qam13
32427500003.240256 qam14
4250750000340256 qam15
5258750000340256 qam16
62667500003.240256 qam17
72747500002.940256 qam18
82827500002.940256 qam19
92907500002.940256 qam20
10298750000340256 qam21
113067500002.940256 qam22
123147500002.740256 qam23
133227500002.740256 qam24
14370750000340256 qam26
153787500002.740256 qam27
163867500002.540256 qam28
173947500002.740256 qam29
184027500002.940256 qam30
194107500002.740256 qam31
204187500002.240256 qam32
214267500002.240256 qam33
224347500002.240256 qam34
23442750000240256 qam35
244507500002.240256 qam36
1Locked40.3140
2Locked40.360
3Locked40.950
4Locked40.940
5Locked40.350
6Locked40.950
7Locked40.970
8Locked40.360
9Locked40.380
10Locked40.350
11Locked40.350
12Locked40.9110
13Locked40.3100
14Locked40.300
15Locked40.360
16Locked40.340
17Locked40.950
18Locked40.350
19Locked40.380
20Locked40.950
21Locked40.330
22Locked40.940
23Locked40.3190
24Locked40.300
