Stormphoenix
  • 30
Message 1 of 13
Bad packet loss and speed drops 4pm onwards
Told to spin this off into its own thread as it was in someone elses.
My usual speeds are ~300-350MB until 4pm rolls around and then it drops to less than 0.5MB. However streaming services such as Youtube and Netflix are unaffected. This has happened for the last 2 days. On the other thread two other people were having the exact same issue and posted near identical BQM graphs.
I'm on 350MB package, Hub 3 in modem mode.
Yesterday's BQM
Today's BQM
Router stats:
331000000
Locked
Ranged Upstream Channel (Hz)
46200046
Locked
Provisioning State
Online
13310000001.238256 qam25
22670000000.738256 qam17
32750000000.738256 qam18
4283000000138256 qam19
52910000001.238256 qam20
62990000001.538256 qam21
73070000001.238256 qam22
8315000000138256 qam23
93230000001.238256 qam24
103390000001.538256 qam26
113470000001.738256 qam27
123550000001.738256 qam28
133630000001.538256 qam29
143710000001.538256 qam30
153790000001.538256 qam31
163870000001.538256 qam32
173950000001.538256 qam33
184030000001.738256 qam34
194110000001.738256 qam35
20419000000238256 qam36
21427000000238256 qam37
224350000001.938256 qam38
234430000001.538256 qam39
244510000001.738256 qam40
1Locked38.690
2Locked38.6150
3Locked38.6220
4Locked38.9140
5Locked38.9110
6Locked38.650
7Locked38.6100
8Locked38.9140
9Locked38.9120
10Locked38.6120
11Locked38.690
12Locked38.650
13Locked38.640
14Locked38.9110
15Locked38.960
16Locked38.6210
17Locked38.9120
18Locked38.960
19Locked38.9100
20Locked38.990
21Locked38.660
22Locked38.990
23Locked38.6200
24Locked38.950
Stormphoenix
  • 30
Message 2 of 13
Re: Bad packet loss and speed drops 4pm onwards
14620004638.5512064 qam3
23940001438.5512064 qam4
35369999140512064 qam2
46030006340512064 qam1
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
9873254k;fg87dsfd;kfoA,.i
SFID16439
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID16330
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
etwork Log
24/06/2021 19:05:15noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2021 21:51:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2021 21:04:20noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/06/2021 21:04:20ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 18:04:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 09:04:20noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/06/2021 09:04:20ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/06/2021 13:50:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/06/2021 03:27:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 21:04:19noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 21:04:19ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 19:04:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/06/2021 04:08:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2021 18:12:39noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2021 15:58:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/06/2021 12:37:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2021 09:12:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2021 09:04:19noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2021 09:04:19ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/06/2021 22:52:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MckeithyB
  • 23
Message 3 of 13
Yeah - I was the OP, and I didnt have a problem with you posting on it - was the same issue.
For what its worth, our BQM graphs are very similar
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a256fcdad81196bc9ed49a2ed7f2b0a982...
Fast.com for me is 400+Mpbs
Various ookla speed test servers are showing aound  10down/40up https://www.speedtest.net/my-result/d/38014dfa-b141-4c39-b478-4e947cec989c
I'm on the 1Gig package. Hub 4 modem.  Sites that VM peer with seem appear ok, so I suspect there's a core network load issue that we're not going to find out about.
Did you notice that the problem from yesterday disappeared around midnight, and reappeared again at 3.45 ?
Stormphoenix
  • 30
Message 4 of 13
It disappeared around midnight and reappeared around 4pm today for me.
Stormphoenix
  • 30
Message 5 of 13
Day 3 of same issue.
I can't watch the football anymore on iPlayer due to this. Getting **bleep** off with the lack of service now.
MckeithyB
  • 23
Message 6 of 13
Same here.
Clearly its not an issue at the customer end as  some peered services are OK.
I'll try running a few traceroutes and see if that reveals anything.
Whereabouts are you? I'm in Surbiton, KT5 and I think we're connected to Croydon via New Malden.
MckeithyB
  • 23
Message 7 of 13
Thinkbroadband (that provide the broadband quality monitors) appear to use cloudflare, and my traces seem to show that it's cloudflare that have the issue (I believe virgin may peer with cloudflare).
Cloudflare of course host all sorts of stuff, so that might be our smoking gun.
Anyone who knows more about these things care to comment?
IssueResolution
  • 39
Message 8 of 13
I have this issue as well, every day starting around 4pm until midnight some websites become very slow. Other websites are unaffected. It appears to affect Cloudflare sites as the other poster said, but I'm also noticing it on some non-cloudflare sites as well. Connected to Croydon headend. I found some twitter messages from random people also talking about it and mentioning Croydon
https://twitter.com/MrReaver85/status/1408871993722785794
https://twitter.com/SynapseZero/status/1408872867228495879
https://twitter.com/alcomatt/status/1408507978391732227
Here is a traceroute
Tracing route to 104.19.129.108 with TTL of 42:
1 8ms 5ms 11ms 10.53.38.213
2 6ms 9ms 7ms croy-core-2a-xe-312-0.network.virginmedia.net [81.96.231.17]
3 * * * Request timed out.
4 44ms 51ms 46ms tele-ic-7-ae2-0.network.virginmedia.net [62.253.175.34]
5 68ms * * 2-14-250-212.static.virginm.net [212.250.14.2]
6 52ms 55ms 53ms 104.19.129.108
Traceroute complete
Darryl24
Message 9 of 13
I've been having the same issue this week, but I'm not sure if this is actually a Virgin Media issue now. If I connect via a VPN (I'm using NordVPN) to a node in the UK I get the same speed and packet loss problem to some sites (and in online games too). If I connect to a node in Germany, those same sites and (games) load and work fine for me.
Barrerayy
  • 28
  • 7
Message 10 of 13
Same problem for me also in Croydon
