stoffle
  • 56
Message 1 of 9
BS11 Intermittent disconnects
This has been happening on and off since last Saturday, it can be any time of the day or evening. It doesn't happend often and sometimes is just a one off but other times it will keep disconnecting and reconnecting for 20 minutes.
stoffle
  • 56
Message 2 of 9
Re: BS11 Intermittent disconnects
stoffle
  • 56
Message 3 of 9
Downstream
14030000000.540256 qam30
22030000002.240256 qam9
32110000002.240256 qam10
4219000000240256 qam11
52270000001.940256 qam12
62350000001.738256 qam13
72430000001.740256 qam14
82510000001.740256 qam15
9259000000238256 qam16
102670000002.740256 qam17
112750000003.240256 qam18
122830000003.240256 qam19
13291000000340256 qam20
14299000000340256 qam21
153070000002.940256 qam22
163150000002.740256 qam23
173230000002.740256 qam24
183630000001.240256 qam25
19371000000138256 qam26
203790000000.538256 qam27
213870000000.238256 qam28
223950000000.238256 qam29
234110000000.940256 qam31
244190000000.740256 qam32
1Locked40.340
2Locked40.350
3Locked40.340
4Locked40.370
5Locked40.350
6Locked38.950
7Locked40.350
8Locked40.360
9Locked38.900
10Locked40.360
11Locked40.350
12Locked40.960
13Locked40.360
14Locked40.340
15Locked40.350
16Locked40.350
17Locked40.300
18Locked40.3100
19Locked38.950
20Locked38.970
21Locked38.690
22Locked38.950
23Locked40.350
24Locked40.340
stoffle
  • 56
Message 4 of 9
Upstream
16030000036.3512064 qam1
25370000036.5512064 qam2
33940000036.3512064 qam4
44620000036512064 qam3
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
3ATDMA0000
4ATDMA0000
stoffle
  • 56
Message 5 of 9
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 00:15:55noticeSW download Successful - Via NMS
14/10/2020 00:12:57noticeSW Download INIT - Via NMS
13/10/2020 10:35:21Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:35:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:35:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:35:15criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:33:28Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:33:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:33:23criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:33:22Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:33:22criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:32:47Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:32:42criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:32:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:10:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/10/2020 17:21:29Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/10/2020 17:21:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
stoffle
  • 56
Message 6 of 9
Nevermind I will call Mr 3 step unplug router, plug back in and turn on fix and hopefully they send someone out after the pointless exercise.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 9
You can either phone in (08:00 is the best time) or wait on here for a few days until one of the VM Forum Staff comes along.
stoffle
  • 56
Message 8 of 9
It was getting drowned by the other threads so they might not even notice it.
Lee_R
  • 2.98K
  • 152
  • 286
Message 9 of 9
Hi stoffle, thanks for posting.
I'm sorry to hear you're experiencing an intermittent internet service.  I would like to take a closer look at this for you. To enable me to do so, I am going to send you a private message. Please look out for the purple envelope in the top right of your screen.
Lee_R
