IKbrunel
  • 186
  • 30
Superfast
Message 1 of 8
BROADBAND: B.Q.M. SPEAKS FOR ITSELF
PROBLEMS SINCE YESTERDAY.    Router 'stats all ok.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: BROADBAND: B.Q.M. SPEAKS FOR ITSELF
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
You can either phone in (08:00 is the best time) or wait on here for a few days until one of the VM Forum Staff comes along.
IKbrunel
  • 186
  • 30
Superfast
Message 3 of 8
Thanks:  "There is no issue in your area."
0800 561 0061  "There is a complex fault in your area, our engineers are working hard, we do not know when it will be completed".
This started last night, I hope it is not too intermittent, should be reasonably easy to trace.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 8
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
Then
Can you please
IKbrunel
  • 186
  • 30
Superfast
Message 5 of 8
Sorry, I forgot to mention1: All cables are firmly fixed, I do this on a regular basis.
2. Router stats are all correct, I am aware of what they should be.
3. The router log does show a lot ofthe following, of course as it is losing connection.
03/10/2020 20:00:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 20:00:38criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 19:59:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 19:59:18criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 19:57:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
IKbrunel
  • 186
  • 30
Superfast
Message 6 of 8
04/10/2020 20:06:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/10/2020 20:06:13criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/10/2020 20:05:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
IKbrunel
  • 186
  • 30
Superfast
Message 7 of 8
Monday am.  Now appears to have returned to normal..
IKbrunel
  • 186
  • 30
Superfast
Message 8 of 8
Hello,
You have asked us to keep you up to date on the problem which is affecting your Telephone and TV service(s).
Fault Ref: F008468151
This problem has now been fixed.
The Virgin Media Team
