matt5905
  • 15
BR3 - packet loss since capacity upgrade/move
like many others locally, I've been suffering terrible latency for the last couple of months due to VM acknowledged over-utilisation in the Beckenham/Hayes area. A few days back (overnight 14th/15th) things massively improved, and I'm assuming some work was done to rebalance or add more capacity.
Since then latency has been much more stable but there are still spikes and also regular packet drops. To my untrained eye, hub stats seem ok-ish, but I have been getting T3 timeouts on one of the upstream channels. Here's my live BQM:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a245e568f575b29ca2925547b75cc517fd...
And now here's the hub stats (running in Modem mode as I've had to switch to 4G for anything latency sensitive due to the earlier utilisation problems)
Information
Cable ModemEuroDOCSIS 3.0 Compliant
Serial Number3BW447WM01322
Boot Code VersionPSPU-Boot 1.0.20.1356
Software VersionV1.01.35
Hardware Version3.11
CA KeyInstalled
Acquired Downstream Channel (Hz)290750000Locked
Ranged Upstream Channel (Hz)39400000Success
Provisioning StateOKOperational
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)290750000266750000274750000282750000298750000306750000314750000322750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID2017181921222324
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)0.79-1.91-1.28-0.020.811.291.932.27
RxMER (dB)35.7834.4834.6335.2535.9735.9736.1736.61
Pre RS Errors
4239502881200634287981439636613
Post RS Errors
287291303291281931277279
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID4356
Frequency (Hz)39400000462000003260000025800000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)42.2542.2542.2542.25
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts00011
T4 Timeouts0000
Upstream Burst  Req(1) Init Maint(3) Per Maint(4) Adv Short(9) Adv Long(10) Adv UGS(11)
Modulation Type16QAMQPSK16QAM64QAM64QAM16QAM
Differential EncodingOFFOFFOFFOFFOFFOFF
Preamble Length36384384646464
Preamble Value Offset39666396396396
FEC Error Correction (T)0557145
FEC Codeword Information Bytes (K)1634348822086
Maximum Burst Size0003055
Guard Time Size224848222222
Last Codeword LengthFixedFixedFixedShortenedShortenedShortened
Scrambler On/OffONONONONONON
General Configuration
Network AccessAllowed
Maximum Number of CPEs1
Baseline PrivacyEnabled
DOCSIS ModeEuroDOCSIS 3.0
Config File
SFID168
Max Traffic Rate117000047 bps
Max Traffic Burst42600 bytes
Min Traffic Rate0 bps
Primary Upstream Service Flow
SFID167
Max Traffic Rate10500047 bps
Max Traffic Burst16320 bytes
Max Concatenated Burst16320 bytes
Scheduling TypeBest Effort
First TimeLast TimePriorityError NumberDescription
17/05/2020 13:54:38 GMT17/05/2020 13:54:38 GMTCritical (3)82000200No Ranging Response received - T3 time-out
17/05/2020 09:50:52 GMT17/05/2020 09:50:52 GMTWarning (5)66050310Auth Success - Web login successful.
16/05/2020 22:06:22 GMT16/05/2020 22:06:22 GMTWarning (5)66050310Auth Success - Web login successful.
16/05/2020 20:25:38 GMT16/05/2020 20:25:38 GMTCritical (3)82000200No Ranging Response received - T3 time-out
16/05/2020 20:09:40 GMT16/05/2020 20:09:40 GMTCritical (3)82000200No Ranging Response received - T3 time-out
16/05/2020 20:05:40 GMT16/05/2020 20:05:40 GMTCritical (3)82000200No Ranging Response received - T3 time-out
15/05/2020 21:22:30 GMT15/05/2020 21:22:30 GMTCritical (3)82000200No Ranging Response received - T3 time-out
15/05/2020 21:11:51 GMT15/05/2020 21:11:51 GMTCritical (3)82000200No Ranging Response received - T3 time-out
15/05/2020 21:05:12 GMT15/05/2020 21:05:12 GMTCritical (3)82000200No Ranging Response received - T3 time-out
15/05/2020 21:03:53 GMT15/05/2020 21:03:53 GMTCritical (3)82000200No Ranging Response received - T3 time-out
15/05/2020 20:49:13 GMT15/05/2020 20:49:13 GMTCritical (3)82000200No Ranging Response received - T3 time-out
15/05/2020 20:19:56 GMT15/05/2020 20:19:56 GMTCritical (3)82000200No Ranging Response received - T3 time-out
15/05/2020 20:01:18 GMT15/05/2020 20:01:18 GMTCritical (3)82000200No Ranging Response received - T3 time-out
15/05/2020 08:18:50 GMT15/05/2020 08:18:50 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
15/05/2020 04:53:20 GMT15/05/2020 04:53:20 GMTNotice (6)68010600DHCP Renew - lease parameters tftp file-******** modified
15/05/2020 04:53:20 GMT15/05/2020 04:53:20 GMTError (4)68010400DHCP REBIND WARNING - Field invalid in response
15/05/2020 04:53:16 GMT15/05/2020 04:53:16 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
15/05/2020 04:53:15 GMT15/05/2020 04:53:15 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
15/05/2020 04:53:11 GMT15/05/2020 04:53:11 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
Would be grateful if one of the experts could take a look and see if there are any pointers here?
Cheers,
Matt.
Zoie_P
  • 2.48K
  • 118
  • 196
Re: BR3 - packet loss since capacity upgrade/move
Hi Matt5905,
Thank you for your post I am sorry that you are not having the best service, looking at your downstream levels and packet loss I would like to book an engineer for you. I will pop you over a private message just keep an eye out for the purple envelope 🙂
thanks,
Zoie
matt5905
  • 15
Thanks Zoie,
got your PM, will contact you there.
Cheers!
Matt.
