Jsquires1990
  • 165
  • 12
Dialled in
Message 1 of 19
BQM analysis?
Hi anybody able to say whether these BQM snapshots are normal and to be expected, I recently got Sky Glass and as its totally IPTV I need to ensure that the connection is as normal as can be.
8/4/22
9/4/22
10/4/22
11/4/22
Many thanks in a advance 🙏
Jsquires1990
  • 165
  • 12
Dialled in
Message 2 of 19
Re: BQM analysis?
Just in case the following data is also needed I have supplied the routers upstream and downstream stats.
12910000000.438256 qam20
2139000000038256 qam1
31470000000.238256 qam2
41550000000.538256 qam3
51630000000.238256 qam4
61710000000.438256 qam5
71790000000.438256 qam6
81870000000.538256 qam7
91950000000.538256 qam8
102030000000.438256 qam9
112110000000.238256 qam10
122190000000.238256 qam11
132270000000.238256 qam12
142350000000.238256 qam13
152430000000.238256 qam14
162510000000.538256 qam15
172590000000.438256 qam16
182670000000.538256 qam17
192750000000.438256 qam18
202830000000.538256 qam19
212990000000.738256 qam21
22307000000138256 qam22
233150000001.438256 qam23
243230000001.738256 qam24
1Locked38.913836
2Locked38.93479144
3Locked38.9200059
4Locked38.9176738
5Locked38.6209951
6Locked38.6234931
7Locked38.9196374
8Locked38.9219862
9Locked38.6240653
10Locked38.6254354
11Locked38.9232532
12Locked38.9145327
13Locked38.912897
14Locked38.9174118
15Locked38.9199215
16Locked38.9206919
17Locked38.6205022
18Locked38.6182413
19Locked38.911481
20Locked38.611143
21Locked38.615657
22Locked38.9155110
23Locked38.6154314
24Locked38.614047
16029999641.8512064 qam1
23940001441.8512064 qam4
34620000441.8512064 qam3
45370001441.8512064 qam2
3ATDMA0000
4ATDMA0000
alphaomega16
  • 338
  • 19
Dialled in
Message 3 of 19
Re: BQM analysis?
Cant see images but does your inquiry involve what is discussed here?
https://community.virginmedia.com/t5/Speed/Packet-loss-and-upload-channel-32-qam/td-p/4983921
Jsquires1990
  • 165
  • 12
Dialled in
Message 4 of 19
Re: BQM analysis?
Thanks for the speedy reply, they seem to look similar to my BQM's - In the sense that between 4&10 the yellow is high! Thankfully not much red.
Hopefully the images will be approved ASAP
conman33158
  • 1.68K
  • 134
  • 366
Super solver
Message 5 of 19
Re: BQM analysis?
We are all facing the same thing my friend 😞
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
  • 15.79K
  • 2.1K
  • 4.96K
Message 6 of 19
Re: BQM analysis?
Hi @Jsquires1990
As per the other posters, don't worry about the BQM just now as a large volume of customers are seeing teh same psikes at the same times. This is being looked into by the VM Network Teams.
Looking at your stats, they aappear to be good apart form the downstream Pre and Post RS errors
This may be an accumalation over time and not really affect performance. It would be better if yuo reboot the hub and then post those stats again in an hour or two. Resetting the hub will clear the currently showing errors and reset them to zero whhich will help determine if they are an issue.
I also suggest checking all your cabling, especially the white coaxial cable. Make sure it's snug and tight and free from any kinks.
Dave
Love, love and love, forever - Pele
Jsquires1990
  • 165
  • 12
Dialled in
Message 7 of 19
Re: BQM analysis?
Thanks Guys.
I will reset and post the downstream stats again in a bit when not using the internet.
Jsquires1990
  • 165
  • 12
Dialled in
Message 8 of 19
Re: BQM analysis?
@newapollo wrote:
Hi @Jsquires1990
Here are the requested updated stats... I reset the connection about 1.5 hours ago.
1291000000138256 qam20
21390000000.538256 qam1
31470000000.738256 qam2
41550000000.938256 qam3
51630000000.738256 qam4
61710000000.738256 qam5
71790000000.738256 qam6
81870000000.938256 qam7
91950000000.938256 qam8
102030000000.738256 qam9
112110000000.738256 qam10
122190000000.738256 qam11
132270000000.538256 qam12
142350000000.538256 qam13
152430000000.538256 qam14
162510000000.738256 qam15
172590000000.738256 qam16
182670000000.738256 qam17
192750000000.938256 qam18
20283000000138256 qam19
212990000001.438256 qam21
223070000001.538256 qam22
233150000001.738256 qam23
243230000001.938256 qam24
1Locked38.640
2Locked38.6170
3Locked38.660
4Locked38.970
5Locked38.650
6Locked38.960
7Locked38.950
8Locked38.9200
9Locked38.940
10Locked38.930
11Locked38.650
12Locked38.960
13Locked38.960
14Locked38.960
15Locked38.960
16Locked38.950
17Locked38.640
18Locked38.670
19Locked38.950
20Locked38.650
21Locked38.6120
22Locked38.950
23Locked38.940
24Locked38.950
Many thanks
risc19
  • 946
  • 31
  • 294
Well-informed
Message 9 of 19
Re: BQM analysis?
Stats look good!
If your BQM is anything like mine then as of 6:00pm today its starting looking bad again.
Yesterday was bad from 3:00pm to 11:00pm.
My Broadband Ping - M500 Hub5 Router Mode
Jsquires1990
  • 165
  • 12
Dialled in
Message 10 of 19
Re: BQM analysis?
@risc19 wrote:
Stats look good!
Yes mine are bad between 4pm and 10pm, I am wandering why we are all seeing this issue.
Are Virgin hiding a wider issue? - I am troubleshooting IPTV with Sky and they need to know its not a latency issue but sadly Virgin won't say yes or no. And the BQM could be incorrect!
Its a nightmare.
