sam1970
  • 7
Message 1 of 9
BB Speed dropped significantly
Iam on 108Mbps contract and apart from the usual drop in service every 2-3 months for a couple of hours I had no major issues until two weeks ago. The speed had dropped significantly to 40mb at best using ethernet cable to hub 3 (I used to get the full 108). On wifi the speed drops to 20-25 from the usual 80-90 Mbps. Tried to call Virgin few times but gave up after being on hold for over an hour. I have only got less than 2 months in my contract but if this is not sorted I dont think I will be renewing as Iam paying for a service Iam not getting.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 9
Re: BB Speed dropped significantly
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 9
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
sam1970
  • 7
Message 4 of 9
This is what Iam getting.
R
387000000
Locked
Ranged Upstream Channel (Hz)
32600000
Locked
Provisioning State
Online
sam1970
  • 7
Message 5 of 9
(On here click the Link icon )
I cant click on here..Can you help please?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 9
Use the Reply button not Quick Reply.
linkcamera
sam1970
  • 7
Message 7 of 9
My BQM
Thank you for your help
sam1970
  • 7
Message 8 of 9
Any ideas please? Still not getting more than 40Mbps at best
Buffer6
  • 12.35K
  • 94
  • 655
Hero
Message 9 of 9
Please re-read post 3 again, we'll need more info to determine what the problem might be.
