ak1975
  • 65
Dialled in
Message 1 of 23
B8 High Latency and packet loss
I'm experiencing constant packet loss and high latency. I'm finding it very difficult to work from home.
Kippies
  • 12.44K
  • 859
  • 3.72K
Message 2 of 23
Re: B8 High Latency and packet loss
Umm, we will need a few more deatils to help you...like I dunno...anything?
How are you connecting to your HUB? How are measuring packet loss?
Next-
Go to 192.168.0.1 in your browser, or 192.168.100.1 if in modem mode
Do NOT LOG IN
Post your upstream, downstream and network metrics from your HUB.
Screen captures are nice, C&P will do though.
Someone will get a look for you.
ak1975
  • 65
Dialled in
Message 3 of 23
14/04/2020 23:13:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2020 23:12:22criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2020 23:12:19Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2020 23:12:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2020 23:12:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2020 16:25:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2020 06:38:12ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2020 05:14:52ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2020 04:51:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 19:31:56ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 15:08:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2020 08:25:45ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/04/2020 21:22:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/04/2020 19:32:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/04/2020 11:05:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/04/2020 10:01:51Warning!TEK Invalid - Invalid Key Sequence Number;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 20:55:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/04/2020 18:25:56ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Screenshot 2020-04-16 at 21.27.21.pngScreenshot 2020-04-16 at 21.27.12.pngScreenshot 2020-04-16 at 21.24.05.png
ak1975
  • 65
Dialled in
Message 4 of 23
Duplicate
Kippies
  • 12.44K
  • 859
  • 3.72K
Message 5 of 23
Thats pretty horrible- Ill flag for staff to run some tests.
ak1975
  • 65
Dialled in
Message 6 of 23
Latest result from think broadband, is there no official support in this forum?
Network LogTime Priority Description
17/04/2020 21:35:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2020 18:34:57noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2020 03:21:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2020 22:01:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2020 22:01:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2020 22:01:33criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2020 22:01:28Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2020 22:01:23criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2020 22:01:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1394000004.05512064 qam4
2537000004.05512064 qam2
3462000004.025512064 qam3
4326000004.025512064 qam5
3ATDMA0000
4ATDMA0000
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12670000009.538256 qam17
22750000009.440256 qam18
32830000009.838256 qam19
42910000009.538256 qam20
52990000001040256 qam21
63070000009.838256 qam22
73150000009.938256 qam23
83230000001038256 qam24
93310000009.538256 qam25
103390000001040256 qam26
113470000009.838256 qam27
123550000009.840256 qam28
133630000009.638256 qam29
143710000009.538256 qam30
153790000009.638256 qam31
163870000009.340256 qam32
17395000000938256 qam34
18403000000940256 qam35
194110000009.138256 qam36
204190000009.438256 qam37
21427000000938256 qam38
224350000009.340256 qam39
234430000009.338256 qam40
244510000009.438256 qam41
1Locked38.9190
2Locked40.3170
3Locked38.9110
4Locked38.9270
5Locked40.3170
6Locked38.9190
7Locked38.9250
8Locked38.9130
9Locked38.9220
10Locked40.3250
11Locked38.9420
12Locked40.3260
13Locked38.9180
14Locked38.9210
15Locked38.9170
16Locked40.3170
17Locked38.9180
18Locked40.3220
19Locked38.9220
20Locked38.9240
21Locked38.9140
22Locked40.3270
23Locked38.9160
24Locked38.6290
ak1975
  • 65
Dialled in
Message 7 of 23
It's been weeks like this, can't get through service services by phone and ignored on this forum.
This is todays result.
ak1975
  • 65
Dialled in
Message 8 of 23
ak1975
  • 65
Dialled in
Message 9 of 23
The last 24hrs...Luckily my contract is ending in a month, I'm definitely not renewing, might even end it early.
ak1975
  • 65
Dialled in
Message 10 of 23
