EliasLassalle
  • 7
Message 1 of 18
Awful single thread download speed
Hey
Please could anyone can help or get me in contact with someone who might be able to.
I have had this issue since I moved into this property 3 months ago. My download speed to a single connection is awful compared to multi-connection downloads.
4 of the 6 ethernet connected devices have around 25-40 Mbps download speed over a single-threaded download. All computers receive 500Mbps over a multi-threaded download.
A number of devices within the house, ethernet and wifi connected have matching single and multi-thread download speeds however 4 of them do not and get a max 40Mbps compared to the 500Mbps we are promised.
This issue isn't present when connecting the computer to a different address to a BT router meaning it's not the computers issue alone.
Maybe a similar issue to this thread however some devices are completely fine -https://community.virginmedia.com/t5/Forum-Archive/Single-Thread-HTTP-issue-retruns/td-p/4027825
Single connection speed test  - https://www.speedtest.net/result/12371531773
Different single connection speed test -
Multi connection download speed (All tests on same computer plugged into router, same speed no matter of time of day)
Any ideas or help would be great.
Thanks in advance!
  • 14.08K
  • 1.88K
  • 4.32K
Message 2 of 18
Re: Awful single thread download speed
Hi @EliasLassalle
The image showing the download speed of 506.22Mbps and upload speed of 34.40Mbps has been rejected by the system due to your ip address being visible which is against forum rules.
Dave
  • 19.55K
  • 800
  • 2.07K
Message 3 of 18
Some router betweem you the the test server doing a QoS like SFQ the more threads you make to the server the more speed you get when the router is limiting bandwidth for everyone.
EliasLassalle
  • 7
Message 4 of 18
When no one’s using the internet the download is still caped at around 35Mbps.
  • 6.09K
  • 512
  • 1.57K
Message 5 of 18
Check with Area faults on 0800 561 0061 or if you have a VM landline 150 as small faults are not shown on the VM status page.
You could try connecting a single PC/Laptop to the Hub in Modem mode and see what speeds you get.  This will give the Hub a different WAN IP for routing out.
Try a factory reset?  VM will ask you to so this in any case.
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
Setup a BQM to monitor the incoming circuit  www.thinkbroadband.com/ping
Note all speed tests need to be done wired directly to the Hub with a known good Cat 6 cable, as VM do not recognise wifi tests.
Zak_M
  • 6.12K
  • 315
  • 545
Message 6 of 18
Good afternoon @EliasLassalle
Welcome to the forums and thank you for taking the time to post.
I am sorry to hear that you are still having some issues with your speeds.
Are you connecting directly to the hub with the Ethernet connection or via a switch?
Kind regards,
Zak_M
EliasLassalle
  • 7
Message 7 of 18
Directly via an ethernet cable.
However, other people in the house are going via a switch and they have the same issue as me.
Sofia_B
  • 1.19K
  • 36
  • 99
Message 8 of 18
So sorry to hear this @EliasLassalle
I'm going to pop you a PM for more details so we can look into things for you.
Please look out for a notification in the purple envelope located in the top right hand corner of the screen.
Sofia
Zoie_P
  • 4.86K
  • 203
  • 376
Message 9 of 18
HI EliasLassalle,
Thank you for messaging with us. I have checked over your account and you have not rebooted in 25 days.
If you could reboot and re-test your speed for me, with a wired connection at speedtest.net.
Zoie
EliasLassalle
  • 7
Message 10 of 18
I restarted it. I looked into this a month ago and followed everything. The internet has also been generally rubbish for the past couple of days on top of the download speed for single-thread downloads still being less than 40 Mbps.
Is there a way to elevate this case as the internet is hardly useable at the moment?
I have messaged them online and they sent out a technician who didn't understand or know what to do at all.
