Marmo70
Message 1 of 5
Average speed
Ethernet fine but whilst not too slow my WiFi speed test shows speeds around 268 mbps. Paying for the 512 mbps. Anything I can do? Should I expect better?
Anonymous
Not applicable
Message 2 of 5
Re: Average speed
you are unlikely to get 500 with a wireless connection.
If your ethernet speeds are fine then you are getting the service.
260 over wireless is good and you should be happy with that. Not a lot of people see speeds like that over wireless
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 5
Re: Average speed
The Wi-Fi speed you are getting is pretty good. Wi-Fi can be affected by tens of different outside influences including building construction, other electronic devices, neighbouring Wi-Fi and smart appliances - the list goes on and on.
SCA1972
  • 5.77K
  • 654
  • 1.94K
Message 4 of 5
Re: Average speed
Wireless is easily disrupted by a number of external factors (Thickness of walls and building materials used within them, mirrors, fish tanks, cordless phones, baby monitors, microwave ovens, a neighbour's wireless router, etc.) so it is not something VM can control or guarantee.
Also not all wireless devices will be capable of 512Mbps.  Only my Samsung Galaxy S10e maxes out my 350Mbps connection with most of my wireless devices only getting 200Mbps or less. What devices are you testing on?
If the bottleneck is not your devices then you could look at getting a third party router to improve wireless speeds with the VM hub in modem mode.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
Marmo70
Message 5 of 5
Re: Average speed
Thank you
