strongbow
  • 20
  • 5
Message 1 of 8
Ask for a SH3 or stick with SH2?
I've had a Superhub 2 on M200 for some time and it's generally worked fine, with Wi-fi around the house OK. I use my SH2 as a router rather than in modem mode.
With Volt, I opted to be increased to M350 (only increased as it was offered but don't really need the extra speed) which has now been activated but I'm not getting that speed. No information from VM about this but having read on here I can see that the maximum speed on the SH2 is M200.
I've read a bit about people not liking the SH3. So my question is do I stick with my SH2 and its maximum M200, or ask for a SH3 to get M350? If I stick with my SH2, should I tell VM that I want to go back down to M200? I don't particularly want to pay out for a separate router if I don't need one.
DavidJWalker
  • 781
  • 53
  • 118
Well-informed
Message 2 of 8
Re: Ask for a SH3 or stick with SH2?
one if volt is actice on the account you must be with 02 reboot the router the superhub 2 can handle m300 people don't say to reboot the router to get new speeds the routers don't update them self like the tv packages
My Broadband Ping - Virgin Media 350MB
Using Ultimate Volt bundle
Just another VM user trying to help out so my answers may be wrong. If you do like my answer please mark it as helpful; it may help others
DavidJWalker
  • 781
  • 53
  • 118
Well-informed
Message 3 of 8
its up to you to ask for sh3 that can handle more speed then the old verson
strongbow
  • 20
  • 5
Message 4 of 8
To reboot, do you mean just to turn it off and on again - as if so that doesn't make a difference. Or do I need to do something else?
DavidJWalker
  • 781
  • 53
  • 118
Well-informed
Message 5 of 8
if that does not make a difference ask for the SH3 that does from from the limit of SH2 too like M600 SH4 is from m600 to a 1Gig
  • 6.1K
  • 512
  • 1.57K
Message 6 of 8
You need a Hub 3 for 350. If you want to stay with the SH2 you will need to stay on 200.
strongbow
  • 20
  • 5
Message 7 of 8
Thanks - but I'm asking for an opinion of whether to stick with my SH2, or whether it's better to go to SH3, bearing in mind I'm using it in router mode. I connect my desktop computer via ethernet, but have several Wifi devices.
Therefore, am I better sticking to my SH2 at M200 or should I go to SH3 at M350? I appreciate there's a speed increase but if the SH3 is going to be less reliable or I'm not going to get as good WiFi for instance I'll stick with my SH2. Hopefully, someone with experience of both can advise.
DavidJWalker
  • 781
  • 53
  • 118
Well-informed
Message 8 of 8
i had SH3 before if you put it high your wifi will cover were you want it wifi drops thats a good tip of the SH its been good for a few people i had one faulty SH3 since i upgraded to m350 and to m650 upgrades with the same hub i have internet switches connecting most of my stuff i only use wifi for like tabels some moblies and echo dot all my other stuff is hard wired i keep them in router modes its been good to me with internet switches i have 3 8 ports switches connected all the time its been good at that point now i have SH4 on 1 Gig
