jturn
Area 22 Leeds - High latency, dropped packets and poor BQM
Until approx 2 weeks ago my connection at home was spot on but since approx 27th November my connection has been erratic with dropped packets and high and variable pings.
This is what I have tried
  • I have reset the router a few times.
  • Switched to modem mode and tested - no obvious difference
Here is the live BQM. The red blocks are where I am testing modem mode (which made no obvious difference).
My BQM
Hope someone can help. Literally just signed a new contract with virigin and within a day or two the connection has gone downhill.
Here are my status data (router reset approx 1 hour ago):
314750000
Locked
Ranged Upstream Channel (Hz)
60299971
Locked
Provisioning State
Online
131475000012.340256 qam23
21387500001240256 qam1
314675000011.640256 qam2
415475000011.640256 qam3
516275000011.940256 qam4
617075000011.940256 qam5
71787500001240256 qam6
81867500001240256 qam7
919475000011.940256 qam8
1020275000011.840256 qam9
1121075000011.540256 qam10
1221875000011.540256 qam11
1322675000011.140256 qam12
1423475000011.140256 qam13
1524275000011.340256 qam14
1625075000011.340256 qam15
1725875000011.140256 qam16
182667500001140256 qam17
1927475000010.840256 qam18
2028275000010.440256 qam19
2129075000010.340256 qam20
2229875000011.440256 qam21
2330675000011.840256 qam22
2432275000012.540256 qam24
1Locked40.360
2Locked40.380
3Locked40.3120
4Locked40.3180
5Locked40.9140
6Locked40.9170
7Locked40.3100
8Locked40.380
9Locked40.970
10Locked40.350
11Locked40.390
12Locked40.350
13Locked40.360
14Locked40.370
15Locked40.950
16Locked40.950
17Locked40.970
18Locked40.350
19Locked40.380
20Locked40.350
21Locked40.390
22Locked40.380
23Locked40.960
24Locked40.3200
jturn
Re: Area 22 Leeds - High latency, dropped packets and poor BQM
Additional data from ROuter Status page:
16029997136.5512064 qam1
23940001435512064 qam4
34620000936512064 qam3
45369997936512064 qam2
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
KDHSUBsgvca69834ncxv98732
SFID30396
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID30395
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
10/12/2020 02:11:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/12/2020 02:08:31noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/12/2020 02:07:57noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/12/2020 02:07:50Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/12/2020 22:49:0noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/12/2020 17:25:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2020 18:45:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2020 06:39:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 20:37:28noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 20:37:28ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 00:32:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/12/2020 20:01:42noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/12/2020 15:05:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/12/2020 08:37:28noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/12/2020 08:37:28ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2020 17:15:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2020 00:52:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2020 00:52:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/11/2020 16:19:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/1970 05:50:25ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
All your Downstream Power Levels are too high.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
