Dear all,
Since 27th July my broadband has been terrible. On the M200 Fibre Broadband package. Speed has fallen to basic service levels and failed DNS queries are hovering around the 15% mark. Here is my SamKnows whitebox download trace to show the issue. Note that I was already only receiving 75% of the advertised service since the last engineer visit .
Attaching the required Superhub log and power details (Superhub 2ac):
Downstream ChannelsLock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked | 1 | 139000000 Hz | 256 QAM | 6.2 dBmV | 36.8 dB | 680 | 286 |
Locked | 2 | 147000000 Hz | 256 QAM | 6.4 dBmV | 37.6 dB | 526 | 295 |
Locked | 3 | 155000000 Hz | 256 QAM | 6.3 dBmV | 37.6 dB | 312 | 305 |
Locked | 4 | 163000000 Hz | 256 QAM | 6.3 dBmV | 37.4 dB | 307 | 287 |
Locked | 5 | 171000000 Hz | 256 QAM | 6.5 dBmV | 37.9 dB | 299 | 297 |
Locked | 6 | 179000000 Hz | 256 QAM | 6.4 dBmV | 37.6 dB | 348 | 348 |
Locked | 7 | 187000000 Hz | 256 QAM | 6.3 dBmV | 37.1 dB | 327 | 318 |
Locked | 8 | 195000000 Hz | 256 QAM | 6.4 dBmV | 37.4 dB | 885 | 882 |
Upstream ChannelsLock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked | 10 | 32600000 Hz | ATDMA | 41.3 dBmV | 64QAM | 6400000 Hz | 5120 Ksym/sec |
Locked | 7 | 46200000 Hz | ATDMA | 41.5 dBmV | 64QAM | 6400000 Hz | 5120 Ksym/sec |
Locked | 6 | 53700000 Hz | ATDMA | 42.3 dBmV | 64QAM | 6400000 Hz | 5120 Ksym/sec |
Locked | 8 | 39400000 Hz | ATDMA | 41.5 dBmV | 64QAM | 6400000 Hz | 5120 Ksym/sec |
Date Time Error Number Error Description
16/08/2021 | 12:48:49 GMT | 66050310 | Auth Success - Web login successful. |
16/08/2021 | 12:41:49 GMT | 66050310 | Auth Success - Web login successful. |
16/08/2021 | 11:39:56 GMT | 66050310 | Auth Success - Web login successful. |
16/08/2021 | 11:39:07 GMT | 68010302 | DHCP WAN IP - 86.31.129.188 |
16/08/2021 | 11:38:03 GMT | 68000407 | TOD established |
Time Not Established | Time Not Established | 82000200 | No Ranging Response received - T3 time-out |
Time Not Established | Time Not Established | 84000510 | Downstream Locked Successfully |
16/08/2021 | 11:36:36 GMT | 66050310 | Auth Success - Web login successful. |
16/08/2021 | 11:36:29 GMT | 66050300 | Auth Fail - Web login failed. |
16/08/2021 | 11:36:23 GMT | 66050300 | Auth Fail - Web login failed. |
16/08/2021 | 11:36:17 GMT | 66050310 | Auth Success - Web login successful. |
15/08/2021 | 03:41:14 GMT | 68010300 | DHCP RENEW WARNING - Field invalid in response v4 option |
11/08/2021 | 15:41:09 GMT | 68010300 | DHCP RENEW WARNING - Field invalid in response v4 option |
08/08/2021 | 03:41:03 GMT | 68010300 | DHCP RENEW WARNING - Field invalid in response v4 option |
04/08/2021 | 15:40:57 GMT | 68010300 | DHCP RENEW WARNING - Field invalid in response v4 option |
01/08/2021 | 03:40:51 GMT | 68010300 | DHCP RENEW WARNING - Field invalid in response v4 option |
30/07/2021 | 12:30:24 GMT | 82000200 | No Ranging Response received - T3 time-out |
29/07/2021 | 13:33:16 GMT | 82000200 | No Ranging Response received - T3 time-out |
28/07/2021 | 15:40:45 GMT | 68010300 | DHCP RENEW WARNING - Field invalid in response v4 option |
27/07/2021 | 01:29:22 GMT | 82000200 | No Ranging Response received - T3 time-out |
Any help gratefully received. Thank you
