@ewhitey wrote:
I have a PC with Gigabit connection connected directly to the Hub4 via a Cat 5e Gigabit cable - Distance about 4 to 5 metres.Connected to my hub presently and for all testing are my pc and my iphone 8. I previously had an M600 package with almost identical issues then whilst transiting to the 1Gb package, moved to M200 for about a week and that work flawlessly from start to finish!!!
I had 1Gb installed last week and haven't got anything greater than 943Mbps but overall average is around 4-500Mbps?
I have used countless speedtests and are generally in unison that my connection is slow - Realspeed Samknows shows anything from 350 to 980 but usually is in the 400's.My upload speeds are averaging around 50, latency around 15 and packet loss always less than 1.0 (last check was -0.121.
Regards wifi, my phone on last check using Samknows was 397 to hub and 319 to phone - Ookla test was 479 up and 49.5 down. Overall any test on my phone will show anything from 69Mbps to 500Mbps sitting right next to the router?
I'm confused as to why a) I'm not getting a decent speed e.g. always over say 850 and b. Why my readings are so widely variable?
Last speed test run/ethernet:
nperf.com: down 246 up 51.63
Fast.com: down 290 up 50
Samknows: down 390 down 293
Thinkbroadband: down 215 up 39.7
Ookla Website: down 351 up 52.84
Ookla Windows app: down 676 up 52.80
iPhone 8 Wifi: Ookla app: down 358 up 43.5 Realspeed Samknows: down 397 down 319
With the greatest of respect you should have done your research before buying.
A gigabit port will max out at around 940mb in ideal conditions, so it is impossible to get higher on a single connection with a hub 4. 50mb is the max upload speed on that connection tier.
The hub4 only uses ac wifi (wifi5). The speed will vary massively on the device connecting, distance and interference in your area. Max of about 600 on mine at best.
Your speed are highly variable because either your signal to your hub is out of spec and/or there is not enough capacity to maintain those speeds on your area.
In short, the hub4 is not very good, the infrastructure virgin uses is not very good, virgins advertising is not very good calling it 'one gig'.
In reality the only realistic way to get 1 gig on virgin is to be downloading on multiple devices simultaneously.
