  • 29
Message 1 of 22
Another slow speed on M350 area 20
I'm wondering if anyone can help please? After reading through the other posts mine doesn't seem as bad, but frustrating all the same. I'm getting around 130/140 Mbps download through my pc on an M350 wired connection even after being in touch with customer support who tested the line and then sent me a new Hub 3 router, but still the same results. Having read through some of the reports I'll post the router status data below:
11387500005.137256 qam1
21467500005.137256 qam2
31547500005.338256 qam3
41627500005.538256 qam4
51707500005.838256 qam5
6178750000638256 qam6
7186750000638256 qam7
8194750000638256 qam8
9202750000637256 qam9
102107500006.137256 qam10
11218750000637256 qam11
122267500005.637256 qam12
132347500005.837256 qam13
142427500005.537256 qam14
152507500005.337256 qam15
162587500005.337256 qam16
172667500005.537256 qam17
182747500005.537256 qam18
192827500005.437256 qam19
202907500005.437256 qam20
212987500005.537256 qam21
223067500005.637256 qam22
233147500005.637256 qam23
243227500005.537256 qam24
1Locked37.6650
2Locked37.6410
3Locked38.9330
4Locked38.6380
5Locked38.6380
6Locked38.6460
7Locked38.6300
8Locked38.6410
9Locked37.6340
10Locked37.3240
11Locked37.6340
12Locked37.3280
13Locked37.6190
14Locked37.6270
15Locked37.3270
16Locked37.3440
17Locked37.3810
18Locked37.6410
19Locked37.6400
20Locked37.6840
21Locked37.3670
22Locked37.6630
23Locked37.6630
24Locked37.6
73
0
1462001474.15512064 qam1
2394002074.1512064 qam2
3326002464.075512064 qam3
4537001154.25512064 qam4
3ATDMA0000
4ATDMA0000
  • 6.49K
  • 485
  • 856
Hero
Message 2 of 22
Re: Another slow speed on M350 area 20
In the first instance I would try a different ethernet cable, preferably a Cat 6 cable without any other components in the system.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 29
Message 3 of 22
I'll have a go at that, I wish my broadband was as quick as you, was there something in the two posts of data that made you think of the cable?
  • 6.49K
  • 485
  • 856
Hero
Message 4 of 22
I'm no expert in these things but while you are waiting for the experts to come along a new cable is a simple and quick thing to check.
Mike Robinson
  • 29
Message 5 of 22
Great stuff
  • 2.97K
  • 176
  • 236
Message 6 of 22
Hi peterh87,
Thanks for your post, I'm sorry to hear you're getting some slow speeds.
Can you confirm if you've tested another Ethernet cable?
Looking at your stats there;s nothing standing out as being a major issues.
Let me know if a new Ethernet cable doesn't help and I can pop you over a private message to take a closer look at things.
Alex_Rm
  • 29
Message 7 of 22
Hi Alex, many thanks for your reply, the replacement cable is due today so I'll fit and test to see if that makes any difference, when I've done the test previously via ethernet it's 130/150 very similar to wifi?
  • 6.02K
  • 307
  • 535
Message 8 of 22
Please let us know how the new cabled test goes 🙂
Kind regards,
John_GS
  • 29
Message 9 of 22
Hi many thanks for reply, I have fitted and tested the new cable with various configurations but I'm still getting 120-130 Mbps on wired and very similar wifi, I'll try and attach the router settings but not sure if the forum limit will let me send it all in one go.
1 258750000 5.5 37 256 qam 16
2 138750000 5.5 37 256 qam 1
3 146750000 5.4 37 256 qam 2
4 154750000 5.5 38 256 qam 3
5 162750000 5.6 38 256 qam 4
6 170750000 6 37 256 qam 5
7 178750000 6.1 38 256 qam 6
8 186750000 6.1 38 256 qam 7
9 194750000 6.1 38 256 qam 8
10 202750000 6.3 37 256 qam 9
11 210750000 6.3 37 256 qam 10
12 218750000 6.3 37 256 qam 11
13 226750000 5.9 37 256 qam 12
14 234750000 6 37 256 qam 13
15 242750000 5.8 37 256 qam 14
16 250750000 5.5 37 256 qam 15
17 266750000 5.6 37 256 qam 17
18 274750000 5.9 37 256 qam 18
19 282750000 5.6 37 256 qam 19
20 290750000 5.6 37 256 qam 20
21 298750000 5.9 37 256 qam 21
22 306750000 5.9 37 256 qam 22
23 314750000 6 37 256 qam 23
24 322750000 5.9 37 256 qam 24
1 Locked 37.6 5 0
2 Locked 37.3 7 0
3 Locked 37.6 4 0
4 Locked 38.6 5 0
5 Locked 38.6 6 0
6 Locked 37.6 6 0
7 Locked 38.6 5 0
8 Locked 38.6 20 0
9 Locked 38.6 18 0
10 Locked 37.6 5 0
11 Locked 37.3 5 0
12 Locked 37.6 5 0
13 Locked 37.6 4 0
14 Locked 37.6 5 0
15 Locked 37.6 5 0
16 Locked 37.3 0 0
17 Locked 37.3 6 0
18 Locked 37.6 6 0
19 Locked 37.6 4 0
20 Locked 37.6 7 0
21 Locked 37.6 5 0
22 Locked 37.6 4 0
23 Locked 37.6 5 0
24 Locked 37.6 4 0
1 46200000 4.125 5120 64 qam 1
2 39400000 4.125 5120 64 qam 2
3 32600000 4.075 5120 64 qam 3
4 53700000 4.25 5120 64 qam 4
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxxl35016u-b.cm
SFID 114176
Max Traffic Rate 402500089
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 114175
Max Traffic Rate 38500089
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
20/04/2019 15:58:35 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2019 16:01:2 Warning! Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2019 16:01:2 Warning! TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2019 16:08:50 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2019 19:09:9 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2019 19:11:26 Warning! Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2019 19:11:26 Warning! TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2019 19:46:28 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2019 01:29:41 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2019 15:32:33 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2019 09:25:29 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/09/2019 06:51:26 notice SW Download INIT - Via Config file
11/09/2019 07:05:52 notice SW download Successful - Via Config file
01/01/1970 00:01:46 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/09/2019 07:43:42 notice Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2020 16:22:41 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2020 16:50:21 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2020 20:21:16 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2020 12:20:19 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 6.02K
  • 307
  • 535
Message 10 of 22
Hi Peter, thanks for coming back to us. I've done a background check and no issues are showing. Can you try a speedtest in safe mode for me?
Kind regards,
John_GS
