cornelio_99
Message 1 of 9
Almost ZERO upload speed
Hi. I've been having a problem with my internet since last week. At several times during the day my upload speeds drop to nearly zero (I cant even upload the picture but Ookla says Ping: 10ms, Download: 95.85mbps, Upload: 0.05mbps):
As many people these days, we need a stable internet connection to work from home. Needless to say that this makes it impossible.
I have contacted customer service several times about this already but still no solution. Initially they though it was a faulty modem/hub so they sent a new one and I have the exact same problem. Then they've changed settings several times on their end but the fault stays there.
It has been over a week now. Can anyone help please?
  • 22.33K
  • 2.4K
  • 3.98K
Message 2 of 9
Re: Almost ZERO upload speed
First do a quick check that all of your coax connections are in nice and "finger" tight at the Hub and wall box and at any splitters/attenuators/etc with no “unterminated loose ends, and that the internal wiring is ok with no kinking or chaffing. Also check that all looks good with the outside cabling and wall box.
Then do a 60 second Hub “pinhole reset” with the Hub "switched on" throughout – leave 10’ to stabilise.
If that’s all good.... Post up your Hub/network connection details and someone will check to see if there is a problem there. In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) and hit return. On the first page up [there should be no need to login if you have done so before] click on the “router status” icon at top right (SH2’s) or text at bottom-middle of first page up (Hub3) and then copy/paste 3 FULL sets of data onto here – from the Downstream, Upstream, & Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button a second time).
-tony-
  • 16.5K
  • 1.31K
  • 3.89K
Message 3 of 9
cannot see it being a loose connection but always worth checking - look at the levels as suggested
____________________
Tony
  • 15.9K
  • 687
  • 1.56K
Message 4 of 9
Not that VM could limit lager MTU packets you could see if a lower MTU works.
Run CMD in admin
netsh interface ipv4 set subinterface "Ethernet" mtu=1400
check its changed
https://www.speedguide.net/analyzer.php
cornelio_99
Message 5 of 9
Thanks guys.
I double checked all connections and everything is tight. Last night I also tried reseting the router (60s pressing the pin). Right now it is working as expected, the problem is that the issue comes and goes. So far this week the problem has come back every day at different times. I'll keep it under observation and if (when) it happens again I'll post the Hub/network connection details.
jpeg1
  • 4.52K
  • 254
  • 728
Community elder
Message 6 of 9
If it's an intermittent problem then it would be worth setting up a BQM to see what happens at those times.
cornelio_99
Message 7 of 9
So its happening again now. Posting the configs as requested:
14027500003.237256 qam25
21867500003.738256 qam7
31947500003.538256 qam8
42027500002.938256 qam9
52107500002.937256 qam10
6218750000438256 qam11
72267500003.938256 qam12
82347500004.138256 qam13
9242750000437256 qam14
102507500003.737256 qam15
112587500003.537256 qam16
122667500003.538256 qam17
132747500002.937256 qam18
142827500002.537256 qam19
152907500002.737256 qam20
162987500002.937256 qam21
173067500002.937256 qam22
183147500003.437256 qam23
193227500003.437256 qam24
20410750000336256 qam26
214187500003.236256 qam27
224267500003.236256 qam28
234347500002.736256 qam29
244427500002.736256 qam30
1Locked37.312812928
2Locked38.6701743593
3Locked38.6696043466
4Locked38.6864783360
5Locked37.3369232777
6Locked38.9201262367
7Locked38.6156682023
8Locked38.6108702035
9Locked37.6106491657
10Locked37.399011684
11Locked37.698731270
12Locked38.697391080
13Locked37.6109321086
14Locked37.6118621039
15Locked37.3135291252
16Locked37.3145151327
17Locked37.3137221539
18Locked37.3123861471
19Locked37.3125291580
20Locked36.6163611039
21Locked36.621229988
22Locked36.6279121021
23Locked36.336041907
24Locked36.637929765
1393999045.1512032 qam6
2258001475.1512064 qam8
3325993465.1512064 qam7
4462002395.1512032 qam5
3ATDMA0000
4ATDMA000
0
30/05/2020 14:57:9 Warning! RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
29/05/2020 11:58:38 critical No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 09:37:55 Warning! RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 18:17:37 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 17:59:18 Error DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 16:52:18 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 16:41:0 Error DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 14:12:6 Warning! RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 17:32:6 critical No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 17:27:6 Warning! TCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 17:27:6 Warning! Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 17:00:31 critical No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 16:55:53 notice LAN login Success;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 16:51:5 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 14:26:56 critical No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 14:24:12 Warning! TCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 14:24:12 Warning! Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:30 critical No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 14:20:30 notice SW download Successful - Via Config file
26/05/2020 14:19:14 critical No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
I see a few warnings and critical errors in the log but not sure what they are exactly.
-tony-
  • 16.5K
  • 1.31K
  • 3.89K
Message 8 of 9
some noise on the line and it could do with looking at but the real problem is the upstream levels they are out of spec - you need a tech to sort that
have flagged the thread to VM
Tony
Corey_C
  • 3.37K
  • 183
  • 269
Message 9 of 9
hi Cornelio_99,
I'll be sending you a PM shortly to get your details.
Cheers,
Corey C
