Dmpollitt
  • 6
Message 1 of 9
Advertised as 108mbps only getting 40mbps - Slow Speed
As above these are my down and up speeds, I have never had above 50mbps this is half what I pay for which is advised to be 108mbps?
  • Please help.
Tags (1)
Anonymous
Not applicable
Message 2 of 9
Re: Advertised as 108mbps only getting 40mbps - Slow Speed
are you using wired or wireless?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 9
How are you testing, Wi-Fi or ethernet cable ?
Dmpollitt
  • 6
Message 4 of 9
Both wired and WiFi
Buffer6
  • 11.14K
  • 93
  • 630
Hero
Message 5 of 9
Log in to your Hub and click on Devices connected, tell us what speed your Device is connected to the Hub at.
Dmpollitt
  • 6
Message 6 of 9
both wireless and wired
Emma_C
  • 8.28K
  • 512
  • 559
Message 7 of 9
Hi Dmpollitt,
I'm sorry for the delay in getting back in touch and for the issues you're having with the speeds.
I've tried to run some diagnostics in the background but it's advising me your hub is offline, is this the case?
Are you able to switch it back on or is there no power at all to the hub?
Let us know so we can assist further.
Emma_C - Forum Team
Dmpollitt
  • 6
Message 8 of 9
My hub is online and switched on I have the same issue with Virgin Connect, it will not identify my hub?
Emma_C
  • 8.28K
  • 512
  • 559
Message 9 of 9
Thanks.
So due to that I have booked an engineer for you, you'll be able to find all of the details via your online account.
If the time doesn't suit then you can find another suitable slot. You'll also need to ensure that somebody over the age of 18 is in the property at the time.
Please let us know how things go.
Emma_C - Forum Team
