  • 26
A whole lot of problems
Hi I've recently had a lot of problems mainly since lockdown came into affect which awesome, said nobody ever. Any way I've copied and pasted my downstream/upstream for the past weekend to reflect the different states my router will tend to show Most notable would maybe be the Post RS errors and the single upstream channel.
Here is a google doc of the down streams/uploads if it's allowed i'm not sure if not i'll make a multi page post https://docs.google.com/document/d/1c2PZFLNWsDR7Qatt7KnSxZnOyF-4PgHhxmn9SRWtPSo/edit?usp=sharing
  • 425
  • 9
  • 32
Superfast
Re: A whole lot of problems
Upstream is out of spec, will need an engineer to sort, one of VM support team will reply to post soon.
  • 14.9K
  • 1.17K
  • 3.48K
1st problem is the upstream - only one channel there should be 4 and the one you have is way out of spec at 5.7 - thats actually 57 and 50 is the max
pre and post rs errors are off the scale - they should be zero or there abouts
chack all coax connections are tight - if they are then you need a tech - wait here and vm should sort one
____________________
Tony
  • 1.53K
  • 69
  • 135
Hello daunzey
Sorry to hear of the broadband issues experienced, we're eager to look into this further for you.
I'm going to send you a Private Message to get some more information from you and look forward to hearing back form you.
Rob
