PositiveD
  • 5
Message 1 of 10
95% drop in speed
Hello, I am a broadband user at home with the M200 option of 200 Mbps. For about two weeks, the download speed has collapsed, initially to about 40Mbps and now to 10-20Mbps. The upload speed has remained reasonably constant at10-20 Mbps.
I have tried all the DIY tests and checks suggested on the website, multiple times, every day. No change. An ethernet cable does not make any difference. Same speed on my different devices so it is not device-specific. There was no change to the room and router or cable set-up I can think about. I have tried to access the hub via 192.168.0.1 on the browser but it doesn't recognise the WIFI password, which is strange because I know for sure it is the right password I received with the hub.
Please help.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 10
Re: 95% drop in speed
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
PositiveD
  • 5
Message 3 of 10
Re: 95% drop in speed / My BQM graph
Thank you, here's the BQM link
https://www.thinkbroadband.com/broadband/monitoring/quality/share/40034bb31184675733bef3d6b635b16b969ef3fd
192.168.0.1 does not recognise my Router password and I don't have access to the info you mention for that reason.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 10
You need to use the settings password ...
Hub-3-Password
PositiveD
  • 5
Message 5 of 10
Got it, thank you.
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1146750000-14.529256 qam2
2138750000-835256 qam1
3154750000-17.227256 qam3
4162750000-7.735256 qam4
5170750000-3.737256 qam5
6178750000-2.237256 qam6
7186750000-1.237256 qam7
8194750000-0.938256 qam8
9202750000-0.738256 qam9
10210750000-0.938256 qam10
11218750000-0.738256 qam11
12226750000-0.538256 qam12
13234750000-0.738256 qam13
14242750000-138256 qam14
15250750000-0.438256 qam15
16258750000-0.238256 qam16
172667500000.238256 qam17
182747500000.438256 qam18
192827500000.738256 qam19
202907500000.438256 qam20
212987500000.738256 qam21
223067500001.238256 qam22
233147500001.538256 qam23
243227500001.740256 qam24
1Locked29.67616994440540
2Locked35.51620
3Locked27.214453581325180446
4Locked35.51290
5Locked37.360
6Locked37.3210
7Locked37.650
8Locked38.6120
9Locked38.960
10Locked38.6130
11Locked38.950
12Locked38.650
13Locked38.650
14Locked38.900
15Locked38.640
16Locked38.640
17Locked38.660
18Locked38.650
19Locked38.930
20Locked38.970
21Locked38.630
22Locked38.960
23Locked38.660
24Locked40.350
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1258000314.725512064 qam12
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
PositiveD
  • 5
Message 6 of 10
Network LogTime Priority Description
22/10/2020 14:54:42Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 14:54:30noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 09:48:51Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 09:48:27criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 03:54:27Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 03:54:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 22:05:3Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 22:05:0Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 22:00:4Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 21:59:53Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 21:57:37Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 21:57:25Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 21:57:13Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 21:56:36Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 21:56:15Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 21:56:1Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 21:55:53Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 21:55:40Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 21:55:30Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 21:55:23Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 10
Don't need to go any further with the Hub data.
On your Downstream Channels, several Power Levels are far too low.
You only have one Upstream Channel, we expect to see four.
This will need an engineer to put right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Martin_N
  • 6.18K
  • 257
  • 366
Message 8 of 10
Hi PositiveD,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue with your broadband. What I will do is private message you so we can look into this.
^Martin
PositiveD
  • 5
Message 9 of 10
Thank you, this case is now closed, I had an engineer at home who fixed the problem successfully
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 10
If you know, please tell us what the engineer did.
