MrBenito
  • 6
Message 1 of 14
90mb speed 500mb package
Screenshot (1).pngLucky to pull 100mb but on the 500mb package fault finder and service status both say all is well.
I've reset the hub using the pin hole and restarted it several times, no joy!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 14
Re: 90mb speed 500mb package
I take it you are testing with an ethernet connected device ?
Your speed is indicative of a Network Interface Card (NIC) set at 10/100 instead of 100/1000.
or
Possibly an iffy network cable.
Buffer6
  • 10.45K
  • 92
  • 614
Hero
Message 3 of 14
How are you testing?  Testing should be with an ethernet connection, that's an RJ45 cat 6 cable
between your device and Hub
and your equipment should be Gigabit compatible that's a 10/100/1000 NIC (Network Interface Card)
If you log in to your Hub http://192.168.0.1/  in router mode or http://192.168.100.1/  in modem mode
Click on connected devices and check your device connection speed to the Hub, it should be 1000 Mbps
If it says 100 Mbps then your speed will be less than 100Mbps
MrBenito
  • 6
Message 4 of 14
Have just swapped cables but speeds are the same range on WiFi also
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 14
Forget Wi-Fi.
What is the NIC set to ?
MrBenito
  • 6
Message 6 of 14
It says 100 is it cable my ethernet card is 1gig
MrBenito
  • 6
Message 7 of 14
DESKTOP-SVT81AT **:**:**:**:**:** 192.168.0.18/24 100 Ethernet
Anonymous
Not applicable
Message 8 of 14
you will need a gigabit card to get over 90-100
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 14
Your ethernet card will set  itself to the slowest link in the system.
Try a new Cat 6 cable.
MrBenito
  • 6
Message 10 of 14
Thanks for the help ordered one
