holland29
6mbps download speed / 8mbps upload
Hi everyone, I'm getting max 6mbps download speeds frequently through the day. Upload speed is 8mbps which is expected.
At other times, I get 100mbps (on a 100mbps plan).
Any help is much appreciated, thanks!
BQM link:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/4d9150f346810cc548c968602eb9aadc9d...
Errors:
  • RCS Partial Service
  • Lost MDD Timeout
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Re: 6mbps download speed / 8mbps upload
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
Andruser
  • 5.52K
  • 970
  • 2.28K
You've got dreadful signal to noise ratio on downstream channels 3 & 4, which would explain the poor speeds, and rather low numbers on several other channels.  I've flagged that for the forum staff to advise, so if you give it a few (working) hours they'll respond, saving you the joys of VM's telephone response.  Unless it's a known area fault, then it will probably require a technician visit to fix.
Steven_L
  • 4.01K
  • 300
  • 390
Hey and welcome to the community @holland29.
Sorry to hear of the issues that you've been having with your connection at the moment.
I have tried to locate your account from your community profile but have been unable to look further into your account to investigate this further for you and check to confirm what the community members have said is correct.
I will drop a private message over in a moment, so that we can confirm your details and pass account security to get this looked into.
Steven_L
