Superleeds69
  • 5
600 download speed terrible
Posted this a few times in the last 6 months my WiFi speeds are terrible 12 download max 25 and can be within a metre of hub 3
Connected with ethernet it's 320
Reboots, reset with pin, reset by virgin via phone all done still pants, my friend says his is the same, anyone else?
Anonymous
Not applicable
Re: 600 download speed terrible
wifi can be effected my many factors and is not garanteed by VM.
While the hubs work for most people they are cheap devices. you can always get better wifi with a better device
Superleeds69
  • 5
I'm being thick here but I could use something other than the hub they provide? Seems pointless paying for 600 when you only get max 25, and calling the hub "super" is misleading
Anonymous
Not applicable
the hub 3 and hub 4 are not called super hubs.
they haven't been called superhubs since the SH2ac.
you MUST use the hub as the modem but you can switch it to modem mode and use any better router or mesh system you like. Good routers can range go upto £1000's for most home users anything in the £90-150 range would do for most.
