thenel
  • 140
  • 5
Dialled in
500mg slower than 350mg
hi, I was upgraded from 350mg bb speed to 500mg. my speed is around 100/150mg which is slower now than on 350mg. any ideas?
thanks
  • 35.13K
  • 3.42K
  • 6.69K
Re: 500mg slower than 350mg
Try a reset like this....
...first make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub (leave the coax connected), and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 (a timed sixty) seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time. Passwords will reset to those on the sticker. See if that sorts it.
  • 20.5K
  • 828
  • 2.2K
By wireless?
Akua_A
  • 4.74K
  • 123
  • 324
Hi @thenel,
Welcome back to the community forums and sorry to hear you are having issues with your broadband speeds.
We can understand this is not ideal and we want to best help. Have you tried the great advice given by @jbrennand? Is the issue still ongoing? Are you also able to confirm if the issue is on wired or wireless devices as mentioned by @legacy1
Akua_A
