stobbsie
  • 55
Message 1 of 25
500mbps speed 230mbps
Speed not as expected since upgrading last week from the 200mbps package where I would get speeds a little over 220 but since upgrade to 500mbps have not really seen a change in speeds but upload speed has doubled could someone please look into this for me thankyou .
Reject101
Message 2 of 25
Re: 500mbps speed 230mbps
Your lucky, I am barely getting 50mbps and I am on the 500 package!
Mcnought
Message 3 of 25
This seems to be a common problem and one that has persisted for 5 days.
I've attempted to call their tech support but have been on hold for 30 mins.
Tags (1)
stobbsie
  • 55
Message 4 of 25
Spoiler
I have also tried calling the 150 and all it does is run a test then hangs up ,total nightmare but I’m within my 14 days
WarrenDann
Message 5 of 25
I’m in the same boat as you Stobbsie,
Now on the M500 yet getting a Max of 279mbps testing wifi.
stobbsie
  • 55
Message 6 of 25
I don’t think these speeds are acceptable with being half the speed that they advertise,Would i have upgraded knowing I would get 20mbps more ...not a chance .
stobbsie
  • 55
Message 7 of 25
Just to update I managed to get through to virgin support and they have said there is a fault showing with the router and a replacement is on its way I will post back if this resolved the issues .
stobbsie
  • 55
Message 8 of 25
So the new hub arrived today wow that was fast ,anyway I have had this connected for just over four hours but speeds remain the same so must need an engineer visit to look into this so now have to try to get back through via phone.
stobbsie
  • 55
Message 9 of 25
As of last night my speeds on 3 devices were
42mbps download -2.5mbps up
7mbps down -1mbps up
12mbps down- 2 up
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 25
OK, with the new Hub let's start from the beginning again.
How are you connecting your device, Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
