eagles131
  • 80
Dialled in
Message 1 of 20
500mb speed issues
Hi guys,
Upgrade from 350mb to 500
Was told my old hub3 was OK for the speed, but seems to be worse than 350 connection.
  • Can some let me know which screen shots to post, so some kind person can check stats for me 😁Screenshot_20201001_180958_com.android.chrome.jpg
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 20
Re: 500mb speed issues
What speed do you get using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
eagles131
  • 80
Dialled in
Message 3 of 20
Hi Mike,
Just checked, only getting between 45/65 connected direct and about same on WiFi?
No one else in house connected
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 20
OK, forget about Wi-Fi for now.
Can you go into the Hub Settings then into Connected Devices and report back the connection speed for the ethernet connected device.
eagles131
  • 80
Dialled in
Message 5 of 20
Laptop is only 100mb 🙄
Not good enough to test with
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 20
What speed do you get with the laptop ?
Anonymous
Not applicable
Message 7 of 20
We need all the stats to determine if its a line problem:
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
eagles131
  • 80
Dialled in
Message 8 of 20
It was the laptop I use with speed test.net
Only got around 65 max with few tests
eagles131
  • 80
Dialled in
Message 9 of 20
eagles131
  • 80
Dialled in
Message 10 of 20
