gareth170
  • 653
  • 32
Up to speed
Message 1 of 11
500mb speed issue
i have been having alot of speed issues. i'm on 500Mb but i'm getting between 90Mb to 200Mb ~.. i think my area is starting to get high utilization as the speed is getting worse. can one of the mods look in to this please.
i'm using a cat6 cable.
when i first got the 500Mb i had no issues, i was getting over 550Mb
1323000000-2.438256 qam24
2203000000038256 qam9
32110000001.238256 qam10
4219000000-2.537256 qam11
5227000000-3.738256 qam12
6235000000-338256 qam13
7243000000-2.738256 qam14
8251000000-2.738256 qam15
9259000000-338256 qam16
10267000000-3.238256 qam17
11275000000-537256 qam18
12283000000-6.237256 qam19
13291000000-438256 qam20
14299000000-338256 qam21
15307000000-2.738256 qam22
16315000000-2.238256 qam23
17331000000-2.438256 qam25
18371000000-3.538256 qam26
19379000000-3.738256 qam27
20387000000-3.738256 qam28
21395000000-3.937256 qam29
22403000000-3.738256 qam30
23411000000-3.938256 qam31
24419000000-3.738256 qam32
1Locked38.99625133
2Locked38.6160176150461
3Locked38.66915775882
4Locked37.35149275630
5Locked38.6116386106910
6Locked38.69436647402
7Locked38.6635961089
8Locked38.612094876378
9Locked38.912939875441
10Locked38.68372260804
11Locked37.68832253279
12Locked37.3730963443
13Locked38.963592424
14Locked38.9631202326
15Locked38.641560349
16Locked38.917308321
17Locked38.920941228
18Locked38.63920219
19Locked38.63720180
20Locked38.63711722
21Locked37.31377245635
22Locked38.65170227
23Locked38.63562172
24Locked38.63634141
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1462000214.45512064 qam1
2257999684.275512064 qam4
3326000004.35512064 qam3
4393999794.4512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Anonymous
Not applicable
Message 2 of 11
Re: 500mb speed issue
Your downstream channel powers level aren't very consistent. One channel is at +1.2 and another is -6.2, which is out of spec (-6 to +10 is in spec).
There appears to be a large number of errors as well, which could be considered high depending on how long your HUB has been on since the last reboot.
gareth170
  • 653
  • 32
Up to speed
Message 3 of 11
i think it's been about 2 to 3 weeks since i last rebooted it..
so do you think the power needs to be looked at?
Anonymous
Not applicable
Message 4 of 11
Well at least one channel is out of spec.
VM can check from their side whether they agree an engineer visit is required.
Paul_DN
  • 5.85K
  • 342
  • 620
Message 5 of 11
Hi gareth170,
Thank you for reaching out to us in our community, I am sorry to see your having issues with your speed.
I have had a look our end and can see your levels look much better, I cannot see any issues at all.
Kind regards
Paul.
gareth170
  • 653
  • 32
Up to speed
Message 6 of 11
hi
well i'm still getting very poor speeds between 90-190Mb~
i've been here before about 5 years ago and it took virgin a year to admit there was a high utilization issue in the area and it took 2 years to get it fixed..
  • 22.48K
  • 2.4K
  • 4.01K
Message 7 of 11
As you are testing on ethernet can you try it this way if you havent.
Connect the ethernet cable, directly to the Hub which you have put into “modem mode”. Test at speedtest.net (not the App!) to your nearest VM server - try on 2 different browsers.
If they are still low – boot the device into safe+networking mode and try again.
There are many posts on here where unknown software, corrupted browsers or other connected devices are limiting speeds on tests.
Report back what that gets.
Alex_RM
  • 4.3K
  • 247
  • 327
Message 8 of 11
Hi gareth170,
Are you still having an issue with this?
Can you please follow the advise from jbrennand if so 🙂
Alex_Rm
gareth170
  • 653
  • 32
Up to speed
Message 9 of 11
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 11
What on earth is 'bluesticks' ?
