mrgeumpy152
  • 51
Message 1 of 8
500mb is not an improvement on 350mb
So got an upgrade to 500 from 350 - er…….absolutely no difference in speeds still getting what I got on 350.
Even though router settings say it's been upgraded.
Will it improve over next 24hours? It's only been done about 1.5 hours ago or so
-tony-
  • 16.53K
  • 1.31K
  • 3.9K
Message 2 of 8
Re: 500mb is not an improvement on 350mb
any speed increase should be instant - post the config info and levels
how are you testing - always test wires
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream + config page
____________________
Tony
mrgeumpy152
  • 51
Message 3 of 8
Testing wired
12030000007.340256 qam9
2211000000740256 qam10
32190000006.840256 qam11
42270000006.540256 qam12
52350000006.540256 qam13
62430000006.440256 qam14
72510000006.540256 qam15
82590000006.640256 qam16
9267000000740256 qam17
10275000000740256 qam18
11283000000740256 qam19
12291000000740256 qam20
132990000007.140256 qam21
14307000000740256 qam22
153150000006.940256 qam23
163230000006.640256 qam24
173630000006.540256 qam25
183710000006.540256 qam26
193790000006.540256 qam27
203870000006.340256 qam28
21395000000640256 qam29
224030000005.640256 qam30
234110000005.840256 qam31
244190000005.940256 qam32
1Locked40.350
2Locked40.360
3Locked40.340
4Locked40.950
5Locked40.950
6Locked40.340
7Locked40.960
8Locked40.360
9Locked40.960
10Locked40.990
11Locked40.380
12Locked40.370
13Locked40.370
14Locked40.9210
15Locked40.370
16Locked40.370
17Locked40.990
18Locked40.370
19Locked40.360
20Locked40.970
21Locked40.3140
22Locked40.3120
23Locked40.3150
24Locked40.9240
mrgeumpy152
  • 51
Message 4 of 8
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
Vcb573b2ee9a9587e.cm
mrgeumpy152
  • 51
Message 5 of 8
SFID362262
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
mrgeumpy152
  • 51
Message 6 of 8
Primary Upstream Service Flow
SFID362261
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
-tony-
  • 16.53K
  • 1.31K
  • 3.9K
Message 7 of 8
levels are good post the upstream - try a different speed test site
if that does not help try a reboot - a reset and a speedtest in modem mode
Tony
mrgeumpy152
  • 51
Message 8 of 8
I've just started a Broadband Quality Monitor off as well
