GeddyMortgage
  • 6
Message 1 of 14
500mb - Only getting 90mbs - Wired Connection
As the title suggests,
Last  month we took a contract with the virgin 500mb internet, tried it for the first time today with a hardwired ethernet cable direct from router -> switch ->  PC
And only appear to be getting 90mbs or so.
Any thoughts/ ideas? settings are all completely default.
thanks
Andrew-G
  • 10.08K
  • 1.62K
  • 4.54K
Message 2 of 14
Re: 500mb - Only getting 90mbs - Wired Connection
Usually a faulty Ethernet cable that's causing the hub to drop back to 10/100 ethernet (had exactly this myself last week), or it could be the computer has a 10/100 network adaptor.  Tends to be only old or cheap computers that still have 10/100 adaptors.  If buying a new cable, they're cheap as chips online, and I'd say go for Cat 6a or higher.
GeddyMortgage
  • 6
Message 3 of 14
Thanks for your help, I swapped the cables to try a few different ones. Same.
But I since think i've found the culprit....I'm an idiot and didn't check the age of the 16port switch. It looked pretty old but assumed that it'd definitely be 1000mb..... Though on closer inspection it looks like it is not.
It's a 3COM Baseline 2016 - Model# 3c16470... link below.
https://www.itinstock.com/3com-superstack-3-baseline-10100-16-port-ethernet-switch-3c16470-34046-p.a...
If I swap that over to a 16port gigabyte switch and just remove all the ethernet connections from the old switch and put them into the new one... that will just work?
(the house i'm in has hardwired ethernet running to every room across all three floors, all coming from that old 3com switch in the attic)
Eeeps
  • 907
  • 57
  • 158
Well-informed
Message 4 of 14
Yes, unless the cables that are used are Cat5 (cable type should be printed on the outer sheath)
GeddyMortgage
  • 6
Message 5 of 14
Cat5 is restricted to 100mb?
Andrew-G
  • 10.08K
  • 1.62K
  • 4.54K
Message 6 of 14
Yes, Cat 5 will normally only accommodate 100 Mbps.  Cat 5e will do up to 1 Gig, but it may be pushing your luck on longer runs, and bear in mind the possibility of noise and cable/connector ageing on built in cabling.  The more switches and junctions in the network, the more chance the hub will decide to limit connection speed.  And as per my own findings the other week, a cable that's nominally 5e or better ( which is almost any you;d encounter these days as basic Cat 5 was deprecated as a standard back in 2001) can still go bad, and then will sometimes flip between 1000 and 100 Mbps.
GeddyMortgage
  • 6
Message 7 of 14
Looks like i'm in luck with the cables atleast. They do appear to say cat5e on them.
Though my other question thats arisen, is.... this is a 16port switch right? what are the two rack mounted things above it?
It looks like 12 of the blue cat5e cables are going from the switch into the rack mounted thing on top, and all the red cat5e are running from the middle mounted rack to the top mounted one. Then I assume out of the back of the top rack mounted ones are the grey cat5e cables that are feeing the ethernet wall sockets in each of the other rooms in my house. Images below.
https://ibb.co/4KrBCfJ
https://ibb.co/vqbn2s6
Andrew-G
  • 10.08K
  • 1.62K
  • 4.54K
Message 8 of 14
I'm sorry I can't offer any accurate answers.  There's a few people round here who are familiar with rack mounted network gear, hopefully they'll be able to offer their advice.
  • 5.93K
  • 496
  • 1.5K
Message 9 of 14
The top two panels are "patch panels" to which the ends of the house ethernet cables are terminated.  Nothing to worry about.
But yes, you need to replace the 3 Com switch as suggested.  As long as the switch is unmanaged, and suitable for rack mounting, you could use another manufacturer.   Something like TP-Link 24-Port Unmanaged Gigabit Ethernet Switch, Steel Case, 19-inch Rack-Mount(TL-SG1024) - Amazo...
That's a fairly good installation, btw, I wish mine was a neat 🙂
GeddyMortgage
  • 6
Message 10 of 14
thanks! I'll let the previous owner know haha. I believe it was all installed around 2008.
The "patch panels" why are the red cat5e cables running from one of the patch panels to the other? what is the point in doing that?
All the blue ones are running into the top patch panel from the switch....which makes sense to me. But don't understand the rest.
