mattyd81
  • 12
Message 1 of 16
500MB Fibre Broadband Poor Speeds
Hi all
i recently joined virgin media and had superfast fibre 500mb broadband installed. I only have broadband and do not have tv or phone. It is a hub 3.
when the technician left i used my phone to do a speed test next to the router and the technician and it came through at 480mb...great i said.
the day after the speed dropped to 80mb.
virgin media technician came back out and change the connector on the white box where the cable enters the property due to the 'resistence not being sufficient enough to maintain fast connection. He changed this and again ran speed tests and all was fine.
the day after again....broadband is averaging from 50mb - 200mb. i have reset the router twice and now stuck with low speeds.
I see that you can post the diagnostics on here but unsure how to access them.
help would be greatly appreciated
mattyd81
  • 12
Message 2 of 16
Re: 500MB Fibre Broadband Poor Speeds
Cable Modem Status
331000000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
mattyd81
  • 12
Message 3 of 16
1331000000-4.538256 qam25
2203000000-3.238256 qam9
3211000000-3.238256 qam10
4219000000-3.238256 qam11
5227000000-3.538256 qam12
6235000000-3.538256 qam13
7243000000-3.738256 qam14
8251000000-438256 qam15
9259000000-4.238256 qam16
10267000000-4.538256 qam17
11275000000-4.738256 qam18
12283000000-538256 qam19
13291000000-538256 qam20
14299000000-4.938256 qam21
15307000000-538256 qam22
16315000000-4.738256 qam23
17323000000-4.538256 qam24
18339000000-4.538256 qam26
19347000000-4.438256 qam27
20355000000-4.438256 qam28
21363000000-4.438256 qam29
22371000000-4.538256 qam30
23379000000-4.538256 qam31
24387000000-4.538256 qam32
1Locked38.950
2Locked38.960
3Locked38.960
4Locked38.950
5Locked38.950
6Locked38.650
7Locked38.930
8Locked38.950
9Locked38.960
10Locked38.950
11Locked38.940
12Locked38.9110
13Locked38.650
14Locked38.950
15Locked38.950
16Locked38.950
17Locked38.650
18Locked38.600
19Locked38.950
20Locked38.950
21Locked38.940
22Locked38.950
23Locked38.670
24Locked38.600
mattyd81
  • 12
Message 4 of 16
16030000042512064 qam1
23940000042512064 qam4
34620000042512064 qam3
45370000042512064 qam2
3ATDMA0000
4ATDMA0000
mattyd81
  • 12
Message 5 of 16
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053-b.cm
SFID7270
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID7269
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
  • 6.09K
  • 512
  • 1.57K
Message 6 of 16
Stats look okay, maybe DS power is a tad on the low side, but still within spec, -6 to +10.
How are you testing speed?  It should be with a Cat6 or better cable direct to the Hub with a gigabit enabled laptop or PC.  Wifi tests are not recognised by VM as proper testing.
John_GS
  • 14.4K
  • 737
  • 1.34K
Message 7 of 16
Hi mattyd81
Apologies for the lower than expected speed. I've done a check on the system today, no issues are showing, all levels in spec.
How's the speed been since posting and also how are you testing, wired/wireless?
Best,
John_GS
mattyd81
  • 12
Message 8 of 16
Hi John
Managed to test for the first time this weekend, speeds look good but i am finding latency/lag as well as drops in bit rate.
Paul_DN
  • 9.82K
  • 506
  • 990
Message 9 of 16
Hi mattyd81,
Thank you for reaching back out to us and for the update, glad to see the speeds have improved, in regards to the latency So we can get a better idea of what is happening please set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any network dropouts. It does it 24/7/365 and it keeps a visual record of any/all your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and in discussions with us. Make sure you uncheck the “ignore ping from WAN side” box in the settings if you see a wall of "red" - note it will take an hour or two to start seeing a sensible picture. please run this for 72 hours and post the results here so we can have a further look into this for you.
Paul.
mattyd81
  • 12
Message 10 of 16
OK Paul leave it with me and i'll run it
